Can you use the clio master cylinder ?
Posted: Thu Jul 16, 2015 10:36 pm
by Jonny6
Hi guys , rather than make the bullet when combining the clio servo and e30 master cylinder , what's stopping you running the clio master cylinder ? Cheers guys
Re: Can you use the clio master cylinder ?
Posted: Fri Jul 17, 2015 9:50 am
by DanThe
The standard one is too small bore, I believe you can use one from a 'sport' model that had bigger callipers and has a 22mm bore MC or thereabouts. The pipe nuts are different sizes though so you will need to remake the brake pipes too
