Help needed! M52 noise post-cam swap - M52/Dibilias
Posted: Sun May 31, 2015 12:00 pm
After swapping in the Dbilas cams, my M52 now sounds almost tappety (M20 like) after 2000 rpm or so. I swear that it wasn't there before.
Any thoughts on whether this is something to be concerned about? Any need to whip the cam cover off again and check the timing is OK? Everything else seems to be running fine.
Cheers,
Gus
Cheers,
Gus
