Clio brake servo problems.
Posted: Wed Apr 01, 2015 11:32 am
by mopsdrops
Hello;
I've fitted the 2001 clio brake servo in combination with the original e30 master cylinder.
The problem is , my brake pedal doesn't come back far enough like it used to be..
I've tried using a 20mm bullit in my master cylinder, also a 35 or 40mm bullit, without the bullit, ... the pedal just stays the same..
Does someone know what the problem is?
Also the rod in the servo doesn't come as far out , as seen in the M50 swap section on the E30 Wiki page. I've been twisting the rod, but it doesnt come out..
Here are some pictures, help is appreciated.
http://s7.postimg.org/xpmm5okh7/rem1.jpg
http://s1.postimg.org/puza3om33/IMG_2368.jpg
http://s16.postimg.org/y4qhjm46d/servo.jpg
thankyou
Re: Clio brake servo problems.
Posted: Wed Apr 01, 2015 5:28 pm
by bosers
Have you adjusted the push rod under the dash with the pedal held up?
Posted: Wed Apr 01, 2015 5:37 pm
by mopsdrops
No? how does this work??
Posted: Wed Apr 01, 2015 6:13 pm
by bosers
I've done this when I changed from auto to manual, I had to prop the pedal up at top of travel then twiddle the nuts on the push rod behind glove box to make sure it was right length, so maybe making it longer will keep pedal in right position? Just a stab in the dark, hope this helps.
Posted: Wed Apr 01, 2015 10:02 pm
by MrT8064
I think your servo might be faulty. The servo forks should be very hard to push if you try by hand. I don't know about you, but I don't have any adjustment rod on the glovebox side of my clio servo!
I've got another problem with mine. The brake bite point is right at the top of the pedal ”“ I'm guessing this means I need to shorten my 'bullet' by a few mil
Posted: Wed Apr 01, 2015 10:23 pm
by Brianmoooore
mopsdrops wrote:No? how does this work??
It's a pull rod, not a push rod. The rod, which goes across the car behind the heater box, screws into a clevis at each end, has a normal thread at one end, and a reverse thread at the other, so turning it adjusts its length.
There are locking nuts that have to be slackened first, and flats on the rod, near the clutch pedal, that enable the bar to be turned with a 7mm (?) open ended spanner.
Posted: Wed Apr 01, 2015 10:25 pm
by bosers
That's what I was on about, thanks Mr Moooore. If its the wrong length it can affect pedal height, no?
Posted: Wed Apr 01, 2015 10:33 pm
by Brianmoooore
It's purpose is to set the pedal height, and will always need adjusting after changing a servo, although I'm not claiming that this is necessarily the sole problem for the OP.
Most E30s that HAVEN'T had a servo change are also in need of this adjustment in my experience. There should only be a small amount of free play to lift the brake pedal upwards from its rest position.
Posted: Wed Apr 01, 2015 10:37 pm
by MrT8064
Sorry for the hijacking ”“ any ideas if adjusting this will make a difference to my high brake bite point? I'm guessing i'll still need to shorten the little bullet. Thanks
Posted: Thu Apr 02, 2015 8:29 pm
by bosers
Probably, Mr T. Any joy, Mops?
Posted: Fri Apr 03, 2015 11:04 pm
by MrT8064
Put an M50 manifold on today, so took a look at the bullet again whilst everything was off. I shaved it down to around 15mm and now the bite point is about where it used to be.
