Using Getrag 6 Speed - Which driveshaft to suit?
Posted: Wed Feb 04, 2015 11:24 am
by Z2TT
Hi Guys.
I'm assuming this would apply to both S50's and M50's, I got an S50 but I'm asking in the M50 thread since I may got some more views, as I assume the engine would sit in the same general area.
I know with a ZF 5 Speed 328i or M3 Box, a 328i driveshaft is bolt-in and the correct length with no custom mods required.
How about if using a E36 M3 Getrag 6 Speed Manual, which model driveshaft will be a good fit?
Cheers.
Re: Using Getrag 6 Speed - Which driveshaft to suit?
Posted: Sat Feb 07, 2015 9:08 pm
by magpie
you can use an e36 m52 prop but it needs to be shortened and balanced , i'm having this work done soon for £60 ...are you aware that you need to make some sort of custom brackets for the gear box mounting ...
i have pics of a decent design and a bosh it one lol
or this safe looking number available at £50 + post :eek:
Posted: Sat Feb 07, 2015 9:13 pm
by jimbom30cab
in the top 2 pics the gearbox crossmember is actually welded to the 2 brackets also.
The 2 supporting brackets are made from 3mm thick steel
It's strong
Posted: Sat Feb 07, 2015 9:19 pm
by magpie
jimbom30cab wrote:in the top 2 pics the gearbox crossmember is actually welded to the 2 brackets also.
It's strong
do you own a tape measure :skip:
Posted: Sat Feb 07, 2015 9:46 pm
by Acaciastrain360
I have a custom propshaft for getrag 6 speed I had on my m50... PM me if you're interested...
Posted: Sat Feb 07, 2015 9:52 pm
by Acaciastrain360
magpie wrote:you can use an e36 m52 prop but it needs to be shortened and balanced , i'm having this work done soon for £60 ...are you aware that you need to make some sort of custom brackets for the gear box mounting ...
Don't forget E28 rubbers...
