M50B25TU E34 Auto Engine Harness Question
Posted: Thu Nov 27, 2014 9:49 am
by N-Gen
Right, I'm a bit confused about the whole matter so I need some clarification.
The ECU plugs for the engine and trans (I won't be using the auto part of the loom since I pair it with a manual box) is on the passenger side of the car. I'm under the assumption that's correct for an E34 harness.
Should I just open the wiring box and re-arrange the wires to change the plug's location to the driver's side and mount in the standard ECU location next to the steering wheel?
Is there anything I'm missing?
Re: M50B25TU E34 Auto Engine Harness Question
Posted: Thu Nov 27, 2014 5:52 pm
by DanThe
LHD?
The RHD loom is not long enough to get the ECU into a reasonable position under the dash
Posted: Thu Nov 27, 2014 6:45 pm
by N-Gen
It's RHD. So I'll either have to change the harness or house it in the engine bay then?
