few M52B28 questions..
Posted: Wed Jun 18, 2014 3:40 pm
by iamsilverfox
Hi,
Soon to own a h reg 325i e30.
Will be doing a 2.8 m52 conversion, with shaved bay and a few other things. Sourced an s reg e39 528 with a M52B28 in it. However its an auto. Can i use this engine and loom from the e39, with the e30 525 flywheel, starter, box and prop?
thanks
Re: few M52B28 questions..
Posted: Thu Jun 19, 2014 10:52 am
by Jozi
I started with the same engine but ended up getting a cheap e36 328 loom and ecu. I think the wiring is a bit more complicated but I'm no expert on this
Posted: Thu Jun 19, 2014 10:58 am
by ross_jsy
You can use the e30 325i (I assume you mean 325, not 525) gearbox, prop, flywheel and starter although you will have to modify the cross member and gear linkage as the engine sits at a different angle. Also you have to modify either the sump or get the flywheel lightened so they clear
Posted: Thu Jun 19, 2014 11:59 am
by iamsilverfox
ross_jsy wrote:You can use the e30 325i (I assume you mean 325, not 525) gearbox, prop, flywheel and starter although you will have to modify the cross member and gear linkage as the engine sits at a different angle. Also you have to modify either the sump or get the flywheel lightened so they clear
Yeah I read about this. And needed an e34 sump. But it is possible to use the e39 engine and loom and ecu, even though it's an auto and a e39?
Posted: Thu Jun 19, 2014 12:09 pm
by ross_jsy
You can, the auto side isn't a problem but iirc the e39 lump is a bit of a pain to use for some reason
Posted: Thu Jun 19, 2014 9:24 pm
by slim91
There good I've used one it pretty much the same apart from e30 ecu is inside the car e39 is in the engine bay so the loom is shorter just alot Easyer to get an e36 loom
Posted: Thu Jun 19, 2014 10:11 pm
by DanThe
As said get an E36 loom, you can use the E39 ECU as its basically the same.
Posted: Fri Jun 20, 2014 12:36 am
by iamsilverfox
Does the e36 loom and ecu have to come off a M52B28 ? the only reason I'm using an e39 is because of its availability over a 36.
Posted: Fri Jun 20, 2014 8:58 am
by DanThe
323 also uses the same loom/ecu
