S50 oil filter housing
Posted: Wed Mar 26, 2014 1:08 pm
by Rallyprep_UK
Has anybody here done the S50 oil filter housing swap and addition of an oil cooler to your M5x motor ?
Will
Re: S50 oil filter housing
Posted: Wed Mar 26, 2014 11:47 pm
by rich318i
im heading down that road
Posted: Tue Apr 01, 2014 10:37 pm
by winx
I'm going to log my oil temps at silverstone next week to see if it is necessary. Have got an s50 housing if I need to go that way but need to decide what to do with oil cooler. Post up progress please if you go ahead!
Posted: Wed Apr 02, 2014 12:49 am
by rich318i
not sure what temp the oil thermostat opens up at..
Anybody???
Posted: Wed Apr 02, 2014 9:35 am
by Rallyprep_UK
Good question !
Posted: Thu Mar 03, 2016 11:05 am
by Supafly
Bit of an old thread revival but as it's relevant to this thread...
Any outcomes to the checks?
Posted: Thu Mar 03, 2016 12:53 pm
by DanThe
The audible outcome is M52 engines tick a lot less with an oil cooler fitted after some heavy track use :D
Posted: Thu Mar 03, 2016 1:32 pm
by Motorhole
Given the cost of even a used S50 housing (£300-£350 last time I checked), the aftermarket options that allow a sandwich plate type filter cap to be screwed onto an M50 filter housing (from Rally Road and potentially Mocal now too, according to Rix) look quite cost effective.
Posted: Thu Mar 03, 2016 1:34 pm
by DanThe
Are they thermostat controlled though?
Posted: Thu Mar 03, 2016 2:32 pm
by winx
I fitted my s50 housing last year with a cooler in the lower grille and it has dropped temps at least 15 degrees and possibly more so well worth it, I can stay out much longer and keep temps in safer ranges :)
Posted: Thu Mar 03, 2016 2:54 pm
by Motorhole
DanThe wrote:Are they thermostat controlled though?
Nope - provisions must be made for an in-line thermostat which does add another £100 or so to the cost.
Is the thermostat built into the S50 oil filter housing?
Posted: Thu Mar 03, 2016 9:19 pm
by DanThe
It is yes
Posted: Sun Mar 06, 2016 11:24 am
by Carl911rugby
Does anyone on here have any experience of this alternative to the. S50 oil filter housing?
I have got an s50 housing to fit but it looks too much hassle in comparison to the alternative. The car it is going on is a track only m52 e30.
https://www.iemotorsport.com/bmw/E36-en ... ladpt.html
Posted: Tue Mar 08, 2016 10:42 am
by ryan_gwa
Popular in America for obvious reasons.
I found the s50 housing to be a straight swap, I replaced the gasket out of caution and my new m52 tensioner bolted straight on too. No issues with belt alignment that I can see.
Posted: Tue Mar 08, 2016 2:05 pm
by Carl911rugby
Thanks!!
