fuel pump for m50 conversion
Posted: Sun Oct 20, 2013 10:48 pm
hello guys,
basically m50'in an 89 316i with a standard pump and single sender tank.. I've looked into the bigger 6cyl pumps but they fit the duel sender tanks which would mean new pump tank and also the fuel gauge?
A mate recommended using the 318is pump (which worked for him) But then I was told you have to switch the original clocks for the 325 e30 clocks or the rev counter doesnt work correctly..
any advise on the clock and fuel pump would be appreciated.
as soon as the car is sprayed i'll be straight into fitting the m50 and looking into what i need to get it done!
Thanks alot
Thanks alot
