coolant bleeding the system,
Posted: Sat Oct 19, 2013 8:27 pm
having problems bleeding my system,
if i leave the car running with the cap off the fans dont seem to get hot but the water comming out the bleed screw is boiling, ive left it run for a while but im still not sure, my temp gauge has been plumbed in to the coolant system but doesnt read any temperature,
if i drive it around for abour 10 mins, the temp gauge will go up to around half and the heaters come on fine but i just cant seem to get them hot when trying to bleed the system,
im to scared to leave it run to long incase i blow the head gasket or something? , would it just be worth taking it to the garage to bleed?
any help would be appreciated!
