clutch
Posted: Wed Jul 17, 2013 9:57 pm
by Sx279
e30 316 with m52b28
dos anyone have a part number for a clutch when using a m20 flywheel with a e30 325 box?
i was under the impression it was a getrag 260 as i had to make the mount up but now i have checked the side of the box the number on the casing is 240.0.0.0130.91 which has lead me to believe it may be a getrag 240 but i know it came from a 325 m20.
i ordered a clutch for a 325 e30 but the clutch plate is completely wrong on the splines same number but wrong size
and the spring plate dos not fit the flywheel
any ideas boys?
Re: clutch
Posted: Wed Jul 17, 2013 10:27 pm
by jmc330i
You could have a 320i box. I'm sure the 320i box is a 240, but can be used in the 325i - many do as the ratios are close to the Sport ratios.
Any pics of the flywheel and clutch? Will help with identification.
Re: clutch
Posted: Wed Jul 17, 2013 11:04 pm
by Sx279
ill get some pics tomorow when im at work cheers make
