why cant i find e28 m535i mounts
Posted: Thu Jun 13, 2013 11:36 am
by Nas80
no one bloody stocks these anymore! ive tried euro car parts, gsf, mister-auto, smeiddmann (they list it but out of stock), Wallach and nesche don't do e28s, er variety of other places (local motor factors etc)
only places that get them but have to import them.
Dealer can get em but £45 each
The costwolds guys are £40 each
the bmminiparts are £40 each
Meh, anyone recommend anywhere else?
Re: why cant i find e28 m535i mounts
Posted: Thu Jun 13, 2013 12:03 pm
by BATTS91
e28 M5 Mounts ..
http://www.eurocarparts.com/ecp/c/BMW_M ... 545&000461
But you need two left ones iirc
Posted: Thu Jun 13, 2013 1:30 pm
by Brianmoooore
BATTS91 wrote:e28 M5 Mounts ..
OR: http://www.carparts4less.co.uk/search/337110070/p/home
Same part, same box, off of the same warehouse shelf.
Posted: Thu Jun 13, 2013 2:23 pm
by Nas80
awesome thanks lads. the local ECP guy didn't even know what an e28 was! lol thanks again for the help.
Posted: Thu Jun 13, 2013 2:33 pm
by Rav335uk
Tut tut Nas, you give up so easily. :mad:
Posted: Thu Jun 13, 2013 3:09 pm
by mr_dink
E34 M50 mounts work as well.
I have a pair of 318IS mounts here somewhere which would also work.
PM me if interested.
Posted: Thu Jun 13, 2013 5:09 pm
by Nas80
I already ordered new ones, I read on the internet that although e34 ones work they aren't made of the same hardness of rubber?
lol @ rav - at least the correct engine is going into the correct shell - e21 m52b28 ftw!!! :cool: winkeye
Posted: Thu Jun 13, 2013 6:37 pm
by Rav335uk
LOL, you know those engines don't like E21's Nas, one's already cooked the car :D
Posted: Sun Jun 16, 2013 8:39 pm
by Andeep
Is there any different between E28 M5, M535i or 535i engine mounts?
Posted: Sun Jun 16, 2013 8:58 pm
by Jimbob
I used these:
https://www.carparts4less.co.uk/search/337110070/p/home
Not sure how I came across them though!
Posted: Sun Jun 16, 2013 11:11 pm
by jmc330i
Andeep wrote:Is there any different between E28 M5, M535i or 535i engine mounts?
M535i are the same as any M30 mounts.
The E28 M5 (S38) has a different mount on the exhaust side, possibly down to the extra weight of the 24v head (considering the engine tilts that way) and extra heat from the 6 branch. That's why the M5 mounts are recommended for S50 swaps, although I guess the same could be said for M50/52 swaps.
Posted: Mon Jun 17, 2013 1:40 pm
by Andeep
Searching the part number 11811128932 on realoem, it says that the left mount is the same for E28 525i, M5, M535i:
http://www.realoem.com/bmw/partxref.do?part=11811128932
Posted: Mon Jun 17, 2013 1:58 pm
by jmc330i
Yup, that's correct, the left side mounts are the same. It's only right side (exhaust side) that differs on the M5.
Posted: Mon Jun 17, 2013 2:15 pm
by Andeep
Will be ordering a pair of left side ones then.
Would you recommend getting them from BMW or from ECP/similar?
Posted: Sat Jun 22, 2013 12:29 pm
by fonk
So why you cant use e28 right mount? Why only left ones? Got myself a pair ( only paid £10) , been told on this forum to get mounts from e28 :?
Posted: Sat Jun 22, 2013 12:34 pm
by Andeep
Can someone just confirm that I need 2 of these mounts:
http://www.eurocarparts.com/ecp/c/BMW_M ... 41e&000461
Posted: Sat Jun 22, 2013 12:43 pm
by fonk
Andeep wrote:Can someone just confirm that I need 2 of these mounts:
Just messured both mounts right and left on every angle. Both are spot on the same my came out from
E21 635csi , and they look exacly the same as on eurocarparts web.
Posted: Sat Jun 22, 2013 2:29 pm
by jmc330i
fonk wrote:So why you cant use e28 right mount? Why only left ones? Got myself a pair ( only paid £10) , been told on this forum to get mounts from e28 :?
The E28 M5 right side mount is more expensive (and BMW only iirc), so most people will go with 2 left side mounts.
I know the M5 right side is needed on an S50 conversion, but nobody has confirmed if its needed on M50/52.
Fwiw, I've used the E28 M5 rightside specific mount on the three M50 conversions I've done.
Posted: Sat Jun 22, 2013 2:40 pm
by jmc330i
The 635i uses the same round mounts as the 535i etc, so that should be fine.
Posted: Sat Jun 22, 2013 2:41 pm
by Jimbob
I used the 635 mounts on mine without issue.
Posted: Sat Jun 22, 2013 3:26 pm
by Andeep
So it is defo 2 of these that I need? Im not sure which side these are from:
Posted: Sat Jun 22, 2013 3:45 pm
by jmc330i
That's the normal M30 mounts, left and right side (used only on the left side of the E28 M5). That seems to be what people are using on the M50 conversion.
