e30 m50 swap Servo
Posted: Thu May 09, 2013 10:08 pm
by Jamie8GTi
Hello after owning a small 316i for half a year the time finally came to liven her up! i got myself a non vanos m50 engine with just over 100k on the clock! :)
as its currently on small discs and useless drums I'm starting on the brakes first and believe the e30 325i rear arms are the best way to go! then 325i callipers and discs on the front.
But my main question is..
i've removed the old bmw servo and pulled out an old mk2 gti's from a mates garage.. now i know people have used these before but the arm through to the master cylinder is shorter on the mk2.. could i just use some sort of round bar? as a floating spacers or would this be a bit dodgy and need tacking on the end
cheers
Re: e30 m50 swap Servo
Posted: Thu May 09, 2013 11:14 pm
by jmc330i
A spacer between the pushrod in the servo and master cylinder is exactly what you need with the Mk2 servo (and the now favoured Clio servo).
A cut down bolt will do the job, but a decent bit of round bar would be better. The length needed does seem to vary a little, but with some trial and error you should get it right.
No need to tack it on, once you have right length it won't be going anywhere.
Posted: Thu May 09, 2013 11:26 pm
by Jamie8GTi
i was mainly worried about it getting stuck or jamming up, thanks mate!
Posted: Thu May 09, 2013 11:41 pm
by jmc330i
Nothing really for it to jam against. Just make sure the spacer is a good fit in the end of the master cylinder and long enough so there is no slack between the servo rod and master cylinder and it will be fine.
Posted: Thu May 23, 2013 7:29 am
by Restlesssoul
Can anyone tell from what year Clio should be that break servo??
Posted: Thu May 23, 2013 8:03 am
by jmc330i
The plastic wing ones, I think around 2001.
Posted: Thu May 23, 2013 8:08 am
by Restlesssoul
Thank you James :cool:
Posted: Sat Jun 01, 2013 11:53 am
by flashBE
Does the Clio servo bolt on to the firewall without any adjustments?
Posted: Sun Jun 02, 2013 9:11 pm
by balilu91
It should bolt on to the firewall with no adjustments
Posted: Mon Jun 03, 2013 10:51 am
by flashBE
Great, thanks
Posted: Tue Jun 04, 2013 6:23 pm
by flashBE
8200192612
Is this the right one? Clio 1.2 2003
Posted: Tue Jun 04, 2013 9:41 pm
by balilu91
i will check tomorrow if i can find a part number on mine. but the one i got was from a clio 2.0 16v 2003
Posted: Thu Jun 13, 2013 4:57 pm
by Jamie8GTi
the clio mk2 i believe.. the one made in 2.0 sport and 182 cup
