LSD diffs
Posted: Tue Jul 03, 2012 7:37 pm
by e36bmw12
How can I tell the difference between LSDs and wot ratio It could be? if it's tag isn't still on it? It's deff a LSD just don't no witch 1 !!!! Can eny 1 help ples thanks
Re: LSD diffs
Posted: Tue Jul 03, 2012 7:51 pm
by rich318i
count 10 turns on the output and count the number of times the input turns or 100 times to get it spot on.
if your diff is a 3.91 = 39 times at 10 turns - 391 times at 100 turns
3.07 = 30 times at 10 turns - 307 times at 100 turns
Re: LSD diffs
Posted: Tue Jul 03, 2012 8:20 pm
by e36bmw12
Cool i will check that out thanks witch is best?
Re: LSD diffs
Posted: Tue Jul 03, 2012 8:26 pm
by rich318i
what gearbox you running?
Re: LSD diffs
by Brianmoooore
Witch (sic) is best for what and coupled to what gearbox?
Re: LSD diffs
Posted: Tue Jul 03, 2012 8:33 pm
by e36bmw12
I've done 2.8i conversion on my e30 318is I've used the 318is gearbox to a 325i prop to the LSD I've fited just not sure witch one I have it seams to run fine it's stupidly quick of the spot and stupidly fast all together
Re: LSD diffs
Posted: Tue Jul 03, 2012 8:42 pm
by rich318i
not sure with them boxes sorry, i just used the e36 box on mine
Re: LSD diffs
Posted: Tue Jul 03, 2012 11:59 pm
by Brianmoooore
e36bmw12 wrote:I've done 2.8i conversion on my e30 318is I've used the 318is gearbox to a 325i prop to the LSD I've fited just not sure witch one I have it seams to run fine it's stupidly quick of the spot and stupidly fast all together
Something around 3.64 : 1 would be my choice for a road going car. 3.76 : 1 for more acceleration at the expense of relaxed cruising and fuel consumption.
Re: LSD diffs
Posted: Wed Jul 04, 2012 12:07 am
by leeparkes
What speed are you getting at 3k rpm? (Indicated at the speedo)
Re: LSD diffs
Posted: Wed Jul 04, 2012 1:48 am
by e36bmw12
3k rpm in wot gear ??
Re: LSD diffs
Posted: Wed Jul 04, 2012 1:59 am
by rich318i
5th
Re: LSD diffs
Posted: Wed Jul 04, 2012 2:03 am
by e36bmw12
Cool I'll check tomorra morning on me way 2 work thanks
Re: LSD diffs
Posted: Wed Jul 04, 2012 6:34 am
by adit
Re: LSD diffs
Posted: Wed Jul 04, 2012 7:07 am
by e36bmw12
It dose bang on 50 mph at 3k rpm ?
Re: LSD diffs
Posted: Wed Jul 04, 2012 2:25 pm
by leeparkes
You sure thats in 5th gear.
To get that speed its got to be a direct 5th box with something like a 4.1 diff.
Re: LSD diffs
Posted: Wed Jul 04, 2012 4:33 pm
by e36bmw12
yeah for deff i checked on way home to at 3000 rpm in 5th it did bang on 50 mph on the speedo my speedo is couple mph out but wot e30 with mods ant lol so wot dose that mean ??
Re: LSD diffs
Posted: Wed Jul 04, 2012 5:04 pm
by leeparkes
Even with the highest (afaik) 4.45 ratio E30 diff you should be doing 59mph.
Im guessing you have a direct 5th gearbox from an E36 (or similar)
Re: LSD diffs
Posted: Wed Jul 04, 2012 5:12 pm
by maggspower
Have you changed the coding plug in the clocks??
Re: LSD diffs
Posted: Wed Jul 04, 2012 5:51 pm
by leeparkes
maggspower wrote:Have you changed the coding plug in the clocks??
Good call, lol.
Re: LSD diffs
Posted: Thu Jul 05, 2012 7:01 am
by e36bmw12
Yeah I changed that I no its only couple mph out as checked it against my road angel
Re: LSD diffs
Posted: Fri Jul 06, 2012 11:17 am
by e36bmw12
Eny ideas ???
Re: LSD diffs
Posted: Sat Jul 07, 2012 12:08 am
by leeparkes
Are you certain its a 318is gearbox? was it already yours or did you buy it from somewhere, ie ebay etc...
Re: LSD diffs
Posted: Sat Jul 07, 2012 12:22 am
by e36bmw12
i brough the 318is and converted it to 2,8 n the gear box in the 318is is the 1 i left in it so i havent changed it since ive had it how do i no wot gear box i got then ???? grrrrr
Re: LSD diffs
by e30topless
rich318i wrote:count 10 turns on the output and count the number of times the input turns or 100 times to get it spot on.
or you could turn the input until the output has done a full circle
Re: LSD diffs
Posted: Sat Jul 07, 2012 8:48 pm
by e36bmw12
Hi wether been to s**ty to climb around under d Bemer to count the prop turns to so meny wheel turns grrrrr but will deff do as soon as it drys up bit lol thanks to all u guys for all for ur help n advise it's been much appreciated
just 1 more thing dose anyone no of an easy way of finding out wot gearbox I have got in me e30 with out takeong it out of car Coz from wot u guys r saying I haven't got the 1 I thort had Evan more of a head f**k
Re: LSD diffs
Posted: Sat Jul 07, 2012 11:48 pm
by leeparkes
Re: LSD diffs
Posted: Sun Jul 08, 2012 12:09 am
by e36bmw12
Cool will do nice 1
Re: LSD diffs
Posted: Sun Jul 08, 2012 12:32 am
by rich318i
the getrag is the maker of and the number is the amount of torque the box can handle!E36 m52's use ZF boxes that can take 320 torques , as it's the same box as the E36 M3 and others
Re: LSD diffs
Posted: Sun Jul 08, 2012 3:08 am
by e36bmw12
Messed up brain now or wot but I think I've worked out wot LSD and box I've got lol well by calculating my wheel size by all of the different diff ratio's and all the different gearboxes then by the 5th gear ratio at 3000 rpm at 50mph my calculations tell me I have got a 4.10 diff and a 245 getrag gearbox no other combinations work out to my 50mph at 3000rpm in 5th gear that my e30 dose eny 1 got any forts on my calculations and findings or have I just wasted my eavaning lol
Re: LSD diffs
Posted: Mon Jul 09, 2012 5:07 pm
by Barx325i
what tire profiles are you running?
have a go with this:
www.unixnerd.demon.co.uk/revs.html
Re: LSD diffs
Posted: Mon Jul 09, 2012 5:32 pm
by leeparkes
This is what i use ^^^
Re: LSD diffs
Posted: Tue Jul 10, 2012 12:36 am
by e36bmw12
I'm runing on 205/40/17 but I have put my wheel sizes in to my calculations and I tried every e30 gearbox and diffs combinations with each gearboxes 5th gear ratio to each LSD ratio With my e30 doing 50mph at 3000rpm in 5th gear and the only combination that came near at 51mph at 3000rpm in 5th was the 323i sport getrag 245 gearbox with its ( 5th gear ratio being 1.00 ) with the 4.10 diff that was the only combination that worked I don't no anymore I only wanted to no wot LSD I had as tag was missing and it now works out the car must have had a gearbox replacement sumtime in its life be 4 I brought I don't no wether to lol or b grrrrrrrrrrrrrrrrrr !!!!!!!????
Re: LSD diffs
Posted: Tue Jul 10, 2012 8:57 am
by Brianmoooore
The gearbox that your engine was attached to in its original home would give the same results.
Re: LSD diffs
Posted: Tue Jul 10, 2012 12:48 pm
by DanThe
Get a welder brought innit
Re: LSD diffs
Posted: Sat Jul 21, 2012 6:49 pm
by walrus1968
DanThe wrote:Get a welder brought innit
yes i agree...bring a welder from somewhere
