M50 CONV CLIO SERVO ADDED BUT PEDAL IS HARD AND NO BREAK
Posted: Sun Feb 05, 2012 3:02 pm
by s9jja
ive just done a m50 conv i added the clio servo with e30 mc added the washer done to test the breaks but the pedal is so hard and there is no break at all. any ideas what it can be.
i wont need bleeding would it????
Re: M50 CONV CLIO SERVO ADDED BUT PEDAL IS HARD AND NO BREAK
Posted: Sun Feb 05, 2012 3:18 pm
by randomspeedfreak
s9jja wrote:ive just done a m50 conv i added the clio servo with e30 mc added the washer done to test the breaks but the pedal is so hard and there is no break at all. any ideas what it can be.
have you connected the vacum pipe?
Posted: Sun Feb 05, 2012 3:57 pm
by craigieeb
Are you just pumping the pedal without starting the engine......?
Posted: Sun Feb 05, 2012 10:11 pm
by Duke137
willnz wrote:
Have you put the valve in the right way round in the vacuum pipe? Ask me..... :o:
Good to see you posting on here Will 8)
Posted: Sun Feb 05, 2012 11:33 pm
by deanocool
make sure the vac pipe next to the throttle is the right way round if youve removed it. if its not your braking will be terrible and the pedal will harder than the expendables - thats if youve actually connected it up? :?
Posted: Sun Feb 05, 2012 11:41 pm
by s9jja
yes its connected?
Posted: Sun Feb 05, 2012 11:42 pm
by s9jja
craigieeb wrote:Are you just pumping the pedal without starting the engine......?
no ive started the car moved it forwards and back
Posted: Sun Feb 05, 2012 11:43 pm
by s9jja
which valve is that not to sure, what will that do if i havent???
Posted: Mon Feb 06, 2012 1:13 pm
by VW-will
When I put mine on, I had some1 push the pedal so I could locate the pin into the master easier, then slowly release the pedal as I slid it onto the studs :-)
Posted: Mon Feb 06, 2012 6:01 pm
by s9jja
all the vacuum pipes are right seen a few pics too but still cant tell wat it is, the pedal is hard not started or started???????
Posted: Mon Feb 06, 2012 6:05 pm
by eko
s9jja wrote:all the vacuum pipes are right seen a few pics too but still cant tell wat it is, the pedal is hard not started or started???????
Are you sure you have got the servo rod located in the master cylinder and not lodged to the side?
Easy done when fitting on your own as it helps if someone presses the pedal down as mentioned above.
Posted: Tue Feb 07, 2012 12:49 pm
by s9jja
:eek: good idea i shall have a look now lol......
Posted: Wed Feb 08, 2012 12:01 pm
by s9jja
ive checked and the rod is free??????????
Posted: Wed Feb 08, 2012 5:18 pm
by randomspeedfreak
s9jja wrote:ive checked and the rod is free??????????
what do you mean its free?!
get the rod to sit in the piston of the master cylinder as you slide the cylinder onto the brake servo. i recon that could eb it aswell i did it the first time i connected mine up
Posted: Wed Feb 15, 2012 2:22 am
by s9jja
the rod is free ???????????
