				brown temp sensor part no.?
				Posted: Tue Jan 10, 2012 7:31 pm
				by joshce
				Sorry if this is already here somewhere, Ive tried searching for it, just finished the conversion and Ive used the wrong one(its blue instead of brown)
Has anyone got a part number for the brown temp sensor for an m52b28?
				Re: brown temp sensor part no.?
				Posted: Tue Jan 10, 2012 7:33 pm
				by E30BeemerLad
				For the brown sensor, you use a M20 one otherwise your gauge won't read right
				Posted: Tue Jan 10, 2012 8:13 pm
				by Green
				12621710512  brown temp sensor for a m20
				Posted: Tue Jan 10, 2012 10:16 pm
				by Jimbob
				That part number is also listed for the 4 cyl engines, I think Beemerlad is getting confused with the coding plug.
				Posted: Tue Jan 10, 2012 10:40 pm
				by joshce
				Nice one lads, appreciate that!
				Posted: Wed Jan 11, 2012 1:12 pm
				by E30BeemerLad
				Jimbob wrote:That part number is also listed for the 4 cyl engines, I think Beemerlad is getting confused with the coding plug.
No mate, you need M20 brown sensor or your temp gauge won't read correct.
The coding plug is for the tacho
				Posted: Wed Jan 11, 2012 1:39 pm
				by Jimbob
				So there are differences between the M40/M42/M20 brown sensors even though they're the same part number?  Damn...was hoping to save some cash and pinch the one off the M42!
				Posted: Wed Jan 11, 2012 2:14 pm
				by DanThe
				The brown E30 single pin sensors are all the same
				Posted: Wed Jan 11, 2012 2:18 pm
				by Brianmoooore
				All the same, and rarely fail. Any second hand one will be fine.
				Posted: Wed Jan 11, 2012 4:40 pm
				by Jimbob
				Another thing, mine also screwed straight in - didn't need turning down.
				Posted: Wed Jan 11, 2012 7:22 pm
				by joshce
				Might have a look in the scrappers so, cheers
				Re:
				Posted: Thu Jan 12, 2012 11:33 pm
				by deanocool
