Diff ratios
Posted: Thu Jan 05, 2012 11:54 pm
by randomspeedfreak
which diff ratios are people running on the m42 box?
im going to get an lsd and have been offered a 3.73. should i go for that or hold out for a 3.64 or a 3.46?
whats everyone else got and how does it go?
cheers
Re: Diff ratios
Posted: Fri Jan 06, 2012 12:02 am
by JGTI
I guess a 3.73 might be the right compromise for a quick car off the line, and a useable car!
I'm on 3:91, and it's always buzzing
Posted: Sat Jan 07, 2012 4:55 pm
by randomspeedfreak
whats the 3.64 saying boys? anyone got a 3.46?
Re:
Posted: Sat Jan 07, 2012 5:01 pm
by craigieeb
Im using a 3:64 and it's spot on as an all rounder,
But I wished id used a 3:91
Re:
Posted: Sat Jan 07, 2012 5:17 pm
by E30BeemerLad
craigieeb wrote:Im using a 3:64 and it's spot on as an all rounder,
I'll swap you then
Re:
Posted: Sun Jan 08, 2012 8:10 pm
by rich318i
i got a 3:91 but rev's silly
Re:
Posted: Sun Jan 08, 2012 9:03 pm
by hotrodrick
Im running a 3:91 on my m52 with m42 box and I find it way to short. Need something a bit longer for a daily car. Fun off the lights though!
Re:
Posted: Mon Jan 09, 2012 5:30 pm
by e30-EVN
I'm using a 3.64 on my m52 with m42 box...... Imo a 3.91 would make take off quite fun but way to buzzy on duals or motorways!
That said a 3.46 would be to long, with the 3.64 I feel its the best all rounder. Not exactly shy off the line either, and 73-75mph @ 3000rpm. Win win
Re:
Posted: Mon Jan 09, 2012 5:36 pm
by Sanchez
Really depends on your driving style/comfort etc.
3.91 if your not too many motorway miles and lower ratio if your around town or like to give it the beans on the strip/track.
Re:
Posted: Fri Jan 13, 2012 8:25 am
by Hoobs
My e21 runs an e12 LSD with a 3:07 and standard 323i box. I plan to fit a C/R gearbox eventually but the longer gears haven't made my car any less fun to drive and it has enough grunt to pull hard through each gear. I quite like not having to snatch a gearchange quite so quickly too!
Re:
Posted: Sat Jan 28, 2012 10:38 am
by shabalake
I've got a 320i gearbox on mine not sure what diff i got but at 70mph its around 3400rpm i looking for somthing longer 3.64?
Re:
Posted: Sat Jan 28, 2012 1:25 pm
by BATTS91
i have m50 with e36 box and a 4.1 diff ive only test drove down the road and its mental going to try 3.64
Re:
Posted: Sat Jan 28, 2012 1:42 pm
by redcar
BATTS91 wrote:i have m50 with e36 box and a 4.1 diff ive only test drove down the road and its mental going to try 3.64
I thought that if you use the e36 box you need something closer to a 3.0?
Re:
Posted: Sat Jan 28, 2012 8:39 pm
by hotrodrick
What was the 3.91 lsd originally be fitted to?
Re:
Posted: Sat Jan 28, 2012 9:47 pm
by redcar
325i facelift sport
Re:
Posted: Sat Jan 28, 2012 10:08 pm
by DanThe
Re:
Posted: Sun Jan 29, 2012 8:32 pm
by Jimbob
Just been playing around with gear ratios here
http://www.endtuning.com/gearratios.html
It claims there's 350rpm difference between a 4.10 and 3.64 based on an M42 gearbox @ 70mph, I thought it'd be more than that.
Building a 4.27 LSD seems a bit more realistic now as it looks as though it'll do 3300rpm @ 70mph.
Re:
Posted: Wed Feb 01, 2012 10:48 am
by Hoobs
I'm running a 4:1 and was expecting to feel the difference a little more than I do. It does feel better on initial launch but that may simply be that this diff is working better than my old one did?
Re:
Posted: Thu Feb 02, 2012 11:15 pm
by deanocool
batts i had that symptom. i had a 4.10 that had no 1st or 2nd. i bought a 3.64 but it was still way ott and had 2nd but no 1st. then i got a 3.08 of danthe and its virtually spot on. its a tad light which makes for good acceleration and still has a decent top end. if you want a factory drive i would recommend a 2.93. i wouldnt bother with a 3.64 for a road car on an e36 box, better on a track really.
