Help needed please! M52 question
Posted: Fri Nov 25, 2011 5:39 pm
by joshce
Almost have the engine in the car, its an m52b28 with b28 manifold. Under the inlet manifold there are two ports on my car, one has the brown temp sensor and one has the 328i temp sender. My question is this, I have the return coolant pipe coming from the throttle, but with no port in the block.I replaced the only port with the brown temp sensor. Do I have to get another port drilled in the block? or is there a simpler way?
Heres the hose in question
and the end that screws into the block
Also does anyone know of a rubber elbow that fits the M52 throttle when the traction control section is taken off
without the extra throttle shown below,
Re: Help needed please! M52 question
Posted: Fri Nov 25, 2011 6:13 pm
by nickso
Just bin the throttle heater loop, it's not really necessary anyway.
You will need to find out if the traction throttle body is different from the non traction one. If it's different you may need to find a non traction one and use the boot for that. If it's the same then just order a new boot.
Posted: Fri Nov 25, 2011 7:02 pm
by joshce
By binning it, do you mean just remove all the hoses an blank off any ports/holes? Or I's there more to it, any negative effects to getting rid of it?
Re:
Posted: Fri Nov 25, 2011 7:19 pm
by DanThe
After you have taken the hoses off the throttle you will be left with one outlet, the small steel pipe which is attached to the larger steel pipe, just cut it down a bit and weld it up.
There are no ill effects of removing the throttle heater, it needs to be at least -10 for it to be any use
Re:
Posted: Fri Nov 25, 2011 7:46 pm
by joshce
Ok great, just to clarify, on my throttle I have two steel ports, one closer to the inlet manifold, do I blank just one of these or both. Also, sorry to be sponging info, I'm not beside it the engine, where does the other hose(not the one suppose to go into the block) lead to? And should this be blocked?
Re:
Posted: Fri Nov 25, 2011 7:49 pm
by DanThe
Read my previous post again mate 8)
Re:
Posted: Fri Nov 25, 2011 8:02 pm
by joshce
Ok sorry think I got it, I'll be at it again tomorro and check it out, thanks a million!! Really appreciate it!
Re:
Posted: Fri Nov 25, 2011 11:30 pm
by magpie
just bin tat skinny intake and upgrade to the larger m50 2.5 one and gain 20bhp + for around £100.
big bangs for little outlay :idea:
Re:
Posted: Fri Nov 25, 2011 11:43 pm
by leeparkes
Once that traction control elbow has gone an M50 2.5 elbow fits.
+1 on the M50 manifold swap, BMW restricted these lumps on purpose. The price of M50 manifolds do take the pish nowdays, ive seen them go £100+ on ebay.
I love it when i spot one in the scrap yard, last wise purchase was £20. :D
Re:
Posted: Fri Nov 25, 2011 11:49 pm
by magpie
leeparkes wrote:Once that traction control elbow has gone an M50 2.5 elbow fits.
finding an m50 in a yard deserves a reward in it's own right :D
Re:
Posted: Sat Nov 26, 2011 1:35 am
by nickso
Aye but it's frustrating to find 2.0 turds all the time. Even when a 2.5 turns up the Polish chaps with far more time on their hands than me get there first. Wish they would get a proper job instead of buggering me twice :)
