Limp mode again!!
Posted: Fri Oct 28, 2011 4:52 pm
by craigieeb
Just been out, and it seems the car has gone in to limp mode, wont go past 5000 ish,
I havnt had it on the diagnostic yet but from experience,
it'll either be the cam or the crank sensor....AGAIN!!
so question...
I'v got spare cam and crank sensors here,
if i plugged them in would it get it's self out of limp mode? (if they are the problem)
or
do the codes need to be cleared in order for it to run out of limp mode?
Re: Limp mode again!!
Posted: Fri Oct 28, 2011 6:40 pm
by craigieeb
Hmm just realised the spedo has stopped working aswell,
Wonder if thats just a red herring tho
Posted: Fri Oct 28, 2011 6:42 pm
by E30BeemerLad
whenever I have changed a cam or crank sensor in the past it has cured the problem and warp drive was restored without any code clearing etc
Posted: Fri Oct 28, 2011 6:46 pm
by craigieeb
Cool, i'll swap them both over tomorrw, and see if that cures it,
If one of them has gone, i'll be looking in to the warranty of them
and see if I do anything with BMW....?
Probably tell me to fak off tho,
Tossers
Posted: Sat Oct 29, 2011 12:18 am
by DanThe
You need the speedo working mate, check the diff plug
Posted: Sat Oct 29, 2011 3:20 am
by craigieeb
I'll check that first then :D
Posted: Sat Oct 29, 2011 11:48 pm
by samc
craigieeb wrote:gone in to limp mode
too much drink? or could it be an age related issue :mad:
Posted: Sat Oct 29, 2011 11:58 pm
by craigieeb
I get worse after a bottle of jacky-d's
Have her walking like john wayne 8O
Posted: Sun Oct 30, 2011 5:19 pm
by craigieeb
Well, looks like the speedo not working wasnt a red herring after all,
Got under the back of the car and the wires to the diff sensor just fell apart in me hand,
So I cut it right back, stuck some fresh wire on...... Hey presto
Job done
:thumb:
Posted: Sun Oct 30, 2011 5:25 pm
by craigieeb
Job done
:thumb:
Posted: Sun Oct 30, 2011 6:36 pm
by jimbom30cab
nice job, i'll remember that for when it's my turn :D
Posted: Sun Oct 30, 2011 7:31 pm
by e21Jason
M52 ecu needs a speed input from the dash cluster so if the speedo dies it goes into limp mode
Posted: Sun Oct 30, 2011 10:47 pm
by DanThe
e21Jason wrote:M52 ecu needs a speed input from the dash cluster so if the speedo dies it goes into limp mode
Some do, some dont
Posted: Mon Jan 09, 2012 1:54 pm
by rich318i
which ones do need a speed input? my e36 i used had abs and wont pass 5500rpm
