now the car won't fukin start!
Posted: Sat May 28, 2011 1:11 pm
by e30-EVN
From 1 problem to another lol......
Sorted the running issue and now I'm loosing water from the back of the head! I think the wiring loom has pulled on the pipe and this has now happened.
Is there a way of changing this pipe with engine in situe?? I need to change it as she is loosing water now. Maybey the jubilee has worked loose but possibly the pipe has gone
Thanks for any help guys
Re: water pipe on the back of the head??
Posted: Sat May 28, 2011 1:15 pm
by E30BeemerLad
Just the rubber hose should be OK to do with the engine in situ (assuming you can get to the jubilee clip to undo it properly.
You may be lucky and can just do it all from underneath, but otherwise the inlet manifold is coming off :)
Posted: Sat May 28, 2011 1:19 pm
by e30-EVN
Was goin to take the inlet mani off anyway mate,,, so it can be done with engine in then??
Not wanting to take the engine out again :(
Posted: Sat May 28, 2011 1:29 pm
by E30BeemerLad
I can't see why it can't be done with the engine in. IIRC when i fitted my engines I didn't have the pipes attached and will have put all this stuff on after it was on the mounts.
You may have to remove or undo the 4 pot loom cover on the bulkhead as they get in the way as you'll discover when it comes to getting the very rear inlet mani nut undone
Posted: Sat May 28, 2011 1:52 pm
by e30-EVN
Right I've just gone to start my car to take it over to my garage and it will not start! Its turrning over but not starting, I've tried everything with the key ect. What is happening?
The fuel pump is priming and she turns over but will not go! Just turning over and over
Posted: Sat May 28, 2011 2:09 pm
by e30-EVN
Someone please help me, I'm loosing it now to be honest :cry: :cry: :cry:
Posted: Sat May 28, 2011 2:15 pm
by E30BeemerLad
Reach around the front and give the wire to the crank sensor a wiggle, see if that makes any difference. Check you haven't disturbed any plugs underneath the inlet manifold where all the wiring and connectors are dude
Posted: Sat May 28, 2011 2:25 pm
by e30-EVN
No, nothing lee.
Turning but not firing and its going to do my battery at this rate :cry:
Posted: Sat May 28, 2011 2:30 pm
by e30-EVN
It was running an hour ago :cry:
Posted: Sat May 28, 2011 2:40 pm
by threelander
check the lead to the coil buddy
Posted: Sat May 28, 2011 3:15 pm
by e30-EVN
Found the problem! Its not good :( :( :cry: :cry:
Posted: Sat May 28, 2011 3:46 pm
by rancido64
Jesus man, you're having no luck with her since swapping the m52 in :( Hope ya get sorted with the loom ASAP
by E30BeemerLad
go on mate....
Posted: Sat May 28, 2011 3:59 pm
by e30-EVN
I do wish I hadn't bothered mate to be honest! There was nothing wrong with the m50, except the box was shagged so engine had to come out to change it and while I was there I thought more power.... Why not. :(
Lee pm on its way mate :)
Posted: Sat May 28, 2011 4:02 pm
by eko
Nothing too serious I hope?
Posted: Sat May 28, 2011 6:29 pm
by rancido64
Sure it'll be worth it when ya have her going spot on :) Just keep plugging away at her
Posted: Sun May 29, 2011 6:58 pm
by e30-EVN
Right time for an update....
It was a serious problem but thanks to danthe I will have the car up and running thursday I hope.
Symptom- burnt wires in the wiring loom!!
Cause - lambda sensor wire had burnt to a crisp!
Reason this happened was I used lambda sensor wire to extend the front lambda but ran out of this wire so I used 30amp loom wire to extend the back one. This isn't good enough for this so if anyone thinks of doing this DON'T BOTHER!!
It burnt through and apears this is the cause of the running issue above, but atleast now I have ngk plugs instead of bosch ones.
So when dan sends me a new loom she will be all good :)
