m40 gearbox....
Posted: Thu Feb 10, 2011 12:29 pm
by lee
quick one guys, is the e30 m40 box exactly the same as the e36 m40 box?
Re: m40 gearbox....
Posted: Thu Feb 10, 2011 2:10 pm
by e30-EVN
As far as I know they are mate, 320 prop needed with this box
Re: m40 gearbox....
Posted: Thu Feb 10, 2011 4:30 pm
by shedrool83
Also as i found out last night my m40 gearbox from an l-reg e30 touring has the right size shaft to fit the m50/52 spigot bearing.
I had already change it for the small one too
So moral of the story is check first
Re: m40 gearbox....
Posted: Thu Feb 10, 2011 7:08 pm
by e30-EVN
^ aw what a bitch lol, hope you have a bearing puller to make life easier
I didn't have one, you should ave seen what I had to do to get mine out
, made it using 2 long bolts and a couple of washers lol. Did the trick though
Re: m40 gearbox....
Posted: Thu Feb 10, 2011 7:13 pm
by shedrool83
Paper ,water and something the right size to fit the hole is all i used.
Piece of pee pee
Wish the rest of my project was as easy
Re: m40 gearbox....
Posted: Thu Feb 10, 2011 7:16 pm
by e30-EVN
Yeah, worth it in the end though imo
24v FTMFW
Re: m40 gearbox....
Posted: Fri Feb 11, 2011 9:28 am
by lee
can the m42 box and the m40 box both be used? reading so much its all confusing me now!
Re: m40 gearbox....
Posted: Fri Feb 11, 2011 11:58 am
by e30-EVN
Yes mate they can both be used but.....
M40 box =318 or 320 prop (longer front section)
M42 box =325 prop (minus the vibration damper)
if using the m42 box a new m20 spiggot bearing is needed (12mm hole)
Re: m40 gearbox....
Posted: Fri Feb 11, 2011 1:17 pm
by lee
cheers dude
Re: m40 gearbox....
Posted: Fri Feb 11, 2011 7:23 pm
by e30-EVN
With the m42 box I used my 320 linkage yoke, it sits in the hole in the tunnel slightly forward but I overcome this by using a z3 short shift lever rotated 180 degrees.
I'm not sure which linkage is used with the m40 box, I do know that its slightly shorter than the m42 box hence needing the slightly longer 320 prop.
Ant
Re: m40 gearbox....
Posted: Sat Feb 12, 2011 7:59 am
by rancido64
iirc i've seen other people that have used the m40 box saying that they also used the m20 linkages
hth
when i finally do mine i'll confirm this for you as this is the route i intend to go
Re: m40 gearbox....
Posted: Sat Feb 12, 2011 8:09 am
by shedrool83
rancido64 wrote:iirc i've seen other people that have used the m40 box saying that they also used the m20 linkages
hth
Same here .
Re: m40 gearbox....
Posted: Sat Feb 12, 2011 9:59 am
by rancido64
shedrool83 wrote:rancido64 wrote:iirc i've seen other people that have used the m40 box saying that they also used the m20 linkages
hth
Same here .
you have a project thread?
Re: m40 gearbox....
Posted: Sat Feb 12, 2011 1:00 pm
by shedrool83
rancido64 wrote:shedrool83 wrote:rancido64 wrote:iirc i've seen other people that have used the m40 box saying that they also used the m20 linkages
hth
Same here .
http://www.e30zone.net/modules.php?name ... c&t=185411
Just about ready to drop in the lump so not much happened really yet.
Re: m40 gearbox....
Posted: Sat Feb 12, 2011 2:46 pm
by rancido64
/subscribed
i need to keep an eye on as many of these conversion threads as possible so i hopefully can learn from everyone else's mistakes and not have any niggles along the way with mine
(yeah right haha)
