ok guy's what do ineed for 24v?
Posted: Fri Aug 06, 2010 11:03 pm
by magpie
my plan is to buy a turd e36 running and go from there.or is a 5 series better?
regards sumps.or will i need to change the sump/pickup etc.
i hope to use an m42 g/box and will an m20 lightened fly be any good? i also need to know about looms ecu's down to zauts,none vanos/vanos the lot.
Re: ok guy's what do ineed for 24v?
Posted: Fri Aug 06, 2010 11:30 pm
by eko
M52 mate,no question :D
Cooks thread should give you an idea of whats involved/needed.
Posted: Fri Aug 06, 2010 11:35 pm
by magpie
so a 528i and 328i are the same yeah?
Posted: Fri Aug 06, 2010 11:40 pm
by eko
magpie wrote:so a 528i and 328i are the same yeah?
Best with a 328i
Posted: Fri Aug 06, 2010 11:42 pm
by leeparkes
Or 728i
Posted: Fri Aug 06, 2010 11:50 pm
by Cook318IS
528i isnt ideal becuase of the dual vanos on the engine (PITA to install when in an e30) and you need to use a 328i loom anyway.
buy an el cheapo e36 donor - my engine has been free with more in return
Posted: Fri Aug 06, 2010 11:58 pm
by E30BeemerLad
My list of parts
1995 E36 328i M52 Engine - with EWS
328i exhaust manifold from above
E34 525 24v sump, oil pickup pipe & dipstick tube
E30 M3 electric fan - any E36 air con fan will do
E28 M5 rubber engine mounts - about £60 from BMW
Plug & play custom engine loom - DanThe
PLug & play custom electric fan loom - DanThe
Clio bosch servo - get from any plastic winged clio (E30 master cylinder bolts straight up
E30 318iS gearbox
E30 325 clutch & flywheel
E30 320 gear shift rods
Z3 1.9 gear shifter (quickshift) - optional - E30 one works fine
E30 325 propshaft
E30 3.9:1 LSD (it's a bit revvy on the motorway but gets off the line like stink)
E30 M3 scorpion stainless exhaust system - optional - E30 325 system is OK, but the M3 system is 50mm twin tube all the way though and helps a lot.
Custom made PAS pipes
E36 steering rack
Posted: Sat Aug 07, 2010 5:16 pm
by georges867
If you use the e36 rack you shouldn't need custom pas pipes, well i didn't but im doing a M50
http://www.eurocarparts.com/ecp/c/BMW_5 ... 8268b&ENGM
Those are the mounts i used, cheaper than going to BMW.
Defo agree with Beemerlad on the exhaust, im using a E30 325 system and i think its going to restrict it quite abit (my thought is it will get me going) if you can try pick up a stainless system from the start.
Has anyone achieved good power with the standard system?
Dont forget you need a starter motor off a facelift E30 M20 engine if you are using a M20 flywheel and clutch.
Posted: Sat Aug 07, 2010 5:37 pm
by Rav335uk
You need an engine that wont crap it self in a few weeks.
Better off buying a complete as many have done Magpie.
24v :roll: , but at least your going 6pot :mad:
Posted: Sat Aug 07, 2010 6:04 pm
by mattrs
The 2.8 lump had nikasil linings did it not?
Get a 2.7 or 2.8 m20 lump in it! :D
Posted: Sat Aug 07, 2010 7:08 pm
by toby
E30BeemerLad wrote:My list of parts
E30 318iS gearbox
E30 320 propshaft
E36 steering rack
That's a nice concise list. Have you posted it in the M50 development thread as a list like that? If not it would be good to have it there.
Posted: Sun Aug 08, 2010 9:14 am
by Alpina99
Hey Mick,
Seen the light at last ??
Looking forward to your updates,
Posted: Sun Aug 08, 2010 7:19 pm
by magpie
gotta find a good engined e36 first..
then frag it winkeye
i just sold a bloody b20 gear selector :banghead:
Posted: Mon Aug 09, 2010 1:02 pm
by Duke137
E30 318iS gearbox
E30 320 propshaft
E36 steering rack
+ 1
thats a good list... Realised I need one or 2 extras that I "forgot about"
Posted: Sat Aug 21, 2010 5:10 pm
by Rod1-BMW
I should be undertaking this soon also. (when funds allow of course) that shopping list is gonna be useful. thanks :D
Oh and duke, where in derby are you. you're not far from me
Posted: Tue Aug 24, 2010 2:18 pm
by doc323
magpie wrote:gotta find a good engined e36 first..
Thats what i had it for!! :)
Posted: Wed Aug 25, 2010 2:02 am
by Dave_M3
E30 318iS gearbox
E30 320 propshaft
E36 steering rack
Just a few things to add there :)
Custom splined steering shaft - DanThe
E34 Steering U-Js (x2) Any E34 at a scrapy but you need two of them
Above not critical but makes the manifold alittle easier.
E30 brown temp sensor (to give the E30 clocks a reading)
E36 328 rad plus another drives side E30 rad mount (E36 rad wider)
E36 318 air-con fan temp switch
M50 Sump and manifold gaskets as your taking them off and changing them and if your fitting an M50 inlet.
E30 spigot bearing if your using an iS gearbox.
by Dave_M3
E30 318iS gearbox
E30 320 propshaft
E36 steering rack
Posted: Fri Sep 10, 2010 9:59 pm
by Alex
You know it makes sence mick :D
Posted: Fri Sep 10, 2010 10:07 pm
by Rav335uk
I think he's been Dinking toooo much.
Posted: Fri Sep 10, 2010 10:08 pm
by DanThe
Indeedy, get that M42 shitter in the bin and take the righteous path 8)
Posted: Fri Sep 10, 2010 10:13 pm
by Alex
Rav335uk wrote:I think he's been Dinking toooo much.
Mick Knows 24v Is the way forward :)
Posted: Fri Sep 10, 2010 10:33 pm
by Rav335uk
From a 4 pot, 6 pot is the way forward :D
Posted: Thu Oct 07, 2010 3:08 pm
by magpie
seems i now have it all apart from some rubber mounts :D :D
Posted: Thu Oct 07, 2010 7:43 pm
by Dave_M3
So the mighty M42 finally coming out then Mick?
I'd be the same anyway if it wasn't for for our retarded tax system that makes the 2.8 600 euro more a year than an M42.
So it's a case of build a 2.8 baiting 318iS. Already almost as quick as a good 328 so can't take much more for an E30 328 :P
Posted: Fri Oct 08, 2010 9:15 am
by magpie
you said ? ha ha 24v all the way :P
