Oil level sensor
Posted: Sun Aug 01, 2010 8:47 pm
Having some troubles with the oil light on the check panel.
I have wired:
M50 / E30
P1 -> P2
P2 -> P10
and the brown wire on the sensor to ground.
the light still stays on.
To check the wiring is it possible to use a resistor across 2 of the pins to make the oil light go out?
thanks
I have wired:
M50 / E30
P1 -> P2
P2 -> P10
thanks
