Page 1 of 3
My Second M50 Engine......
Posted: Tue Jul 27, 2010 1:49 pm
by Baz666
Re: m50 started tapping
Posted: Tue Jul 27, 2010 8:08 pm
by Duke137
What condition is the exhaust manifold in, would it be that baz?
Posted: Tue Jul 27, 2010 8:21 pm
by DanThe
Have you checked the oil level?
Posted: Tue Jul 27, 2010 8:22 pm
by Baz666
Thats the second time someone has said that will
Have to get it looked at...would the tapping from the manifold
increase with the revs.
Should of stayed with the m20
Posted: Tue Jul 27, 2010 8:25 pm
by Baz666
DanThe wrote:Have you checked the oil level?
Yeah all good Dan.
Posted: Fri Jul 30, 2010 2:46 pm
by Baz666
on the m50 are the tappets adjustable or are they hydraulic.
Posted: Fri Jul 30, 2010 2:52 pm
by E30BeemerLad
hydraulic mate
Posted: Fri Jul 30, 2010 2:53 pm
by Baz666
is that bad news then if there hydraulic.
Posted: Fri Jul 30, 2010 2:55 pm
by E30BeemerLad
check a load of daft things Barry like are the spark plugs in tight, is the exhaust manifold tight to the head, is the lambda sensor in tight?
Where does it sound like the tapping is coming from, top of the engine, front etc etc
Posted: Fri Jul 30, 2010 3:28 pm
by Baz666
well its hard really to hear where its coming from so heres a little video so just incase you might know from sound in the differents, also is`nt the sound of the engine suspose to dye when you take of the oil cap off and spit out oil.
Posted: Fri Jul 30, 2010 3:33 pm
by E30BeemerLad
I can't watch that at work mate, so will have to look at it tonight (but I'm no expert on this crap anyway)
Posted: Fri Jul 30, 2010 3:36 pm
by Speedtouch
That's a clunker alright
Posted: Fri Jul 30, 2010 3:54 pm
by Baz666
ok Thanks
thanks for the obvious
Posted: Fri Jul 30, 2010 4:48 pm
by baptie0
I dont think it sounds too bad, possibly a sticking hydraulic tappet. you could try some engine flush, get the engine nice and hot and change the oil and filter. then thrash it, the m50s are bomb proof
Posted: Fri Jul 30, 2010 4:50 pm
by Baz666
like the sound of that fella
Posted: Fri Jul 30, 2010 7:03 pm
by DanThe
Thats defo a sticky lifter, sounds like your vanos is having a groan also
Posted: Fri Jul 30, 2010 7:32 pm
by E30BeemerLad
Do you know what grade of oil is in it Baz?
Posted: Fri Jul 30, 2010 7:33 pm
by Baz666
Yeah Dan it is a little but when the bonnets down you dont hear it.
Whats the best way around a sticky lifter.
Posted: Fri Jul 30, 2010 9:17 pm
by Baz666
E30BeemerLad wrote:Do you know what grade of oil is in it Baz?
I think it was something like 5/40 grade if this is wrong let me know what to go for.
Posted: Fri Jul 30, 2010 9:20 pm
by Baz666
Use a diesel oil for a while
really what stuff do you reccomend
air leak cheaked all the pipes didnt think i had one.
Posted: Fri Jul 30, 2010 9:50 pm
by Baz666
willnz wrote:5W40, 10W40 (as close as you can get to these) Not sure what grades are available in the UK? (Diesel oil has strong detergents built in to help keep the engine clean)
You must have a leak somewhere, removing the cap should result in a noticeable change in rpm.
Thanks will i`ll look into the air leak, i just carnt get my head around using diesel oil but if it works i`ll try it,
sorry to ask this but can anyone else back up what Willnz is saying.
Posted: Fri Jul 30, 2010 10:15 pm
by E30BeemerLad
Yes, Diesel oil is safe to use for a bit.
Posted: Fri Jul 30, 2010 10:29 pm
by Baz666
thanks buddy but how long is a bit as i would hate to do damage.
Posted: Fri Jul 30, 2010 10:37 pm
by E30BeemerLad
I'd probably do about 200 miles and I wouldn't rev the fanny off it, but it's probably perfectly safe.
If you're brave, parafin & gear oil & leave to tick over for 20 mins would clean her out
Posted: Fri Jul 30, 2010 10:52 pm
by Baz666
ok thanks going to try and sort it this weekend....engine flush and diesel oil
Posted: Fri Jul 30, 2010 11:02 pm
by E30BeemerLad
just diesel oil Baz, no need to buy engine flush too
Have a look here mate
http://www.soarerworld.com/forum/showth ... t=flushing
Posted: Sat Jul 31, 2010 1:51 am
by Baz666
Thanks for that buddy, great read
He talks about doing it to a vvti and as i dont know how much oil one of them takes
Would i do the same 3ltr mix.
We have diesel trucks at work so i can get my hands on loads of them both.
tonight at work i`v got myself 10ltr of 10/40 diesel oil which we use in our trucks from volvo and about the same in transmisson oil which is the same thing isn`t, will these both be ok to use let me know as i`m going to give it a try sometime today.
what i need to know is how much to use...???? the same as if i was butting fresh oil in.
Posted: Sat Jul 31, 2010 2:23 pm
by baptie0
he is adding diesel to the oil, not using diesel oil.
Posted: Sat Jul 31, 2010 3:37 pm
by Baz666
no the way i read it he is adding
Its 4 litres of diesel oil and a litre of gear oil.
http://www.soarerworld.com/forum/showthread.php?t=27600
Posted: Sat Jul 31, 2010 5:51 pm
by Baz666
Right this is my first mix its as above 4ltr diesel oil and 1 ltr gear oil, i will show it as they have done on the website that beemerlad put up....hope this is going to work.
this is not a cherry drink
once it has done it first run i`ll put up pictures of the results.
Posted: Sat Jul 31, 2010 5:59 pm
by E30BeemerLad
You are using gearbox oil and not ATF aren't you baz?
Posted: Sat Jul 31, 2010 6:00 pm
by Baz666
transmisson oil ?? what is ATF ??
Posted: Sat Jul 31, 2010 6:01 pm
by E30BeemerLad
Automatic Transmission Fluid/ PAS fluid
