noisy m52
Posted: Wed Jul 07, 2010 10:08 pm
by vokietis
finished my m52 conversion,started the car and ooops,it has strange ticking/knocking noise,can't really tell where it's coming from
engine was 100% good before i took it out from an e39.
Re: noisey m52
Posted: Wed Jul 07, 2010 10:12 pm
by E30BeemerLad
Could be any number of things, exhaust manifold leaking, flywheel catching on sump, something not done up properly like engine mount, exhaust rubbing on something etc etc etc
Re: noisey m52
by E30BeemerLad
lambda sensors done up tight?
Re: noisey m52
Posted: Wed Jul 07, 2010 10:15 pm
by Jhonno
Did you remove the sump baffles?
Re: noisey m52
Posted: Wed Jul 07, 2010 10:26 pm
by DanThe
Ticking and knocking are two very different noises.
How long had it been out of the 5 before you started again in the E30? My guess is a sticky lifter or two, common if the engine has been sat dry for a long time
Re: noisey m52
Posted: Wed Jul 07, 2010 10:37 pm
by vokietis
Jhonno wrote:Did you remove the sump baffles?
no
Re: noisey m52
Posted: Wed Jul 07, 2010 10:38 pm
by vokietis
DanThe wrote:Ticking and knocking are two very different noises.
well it's more like knocking,and yes it sat dry for about 12 months
Re: noisey m52
Posted: Wed Jul 07, 2010 10:44 pm
by DanThe
This one should be removed
Re: noisey m52
Posted: Wed Jul 07, 2010 10:45 pm
by vokietis
oh no
are u saying crankshaft is touching it?is it possible to remove the sump without removing engine?
Re: noisey m52
Posted: Wed Jul 07, 2010 10:46 pm
by DanThe
I can imagine what is happening...
Re: noisey m52
Posted: Wed Jul 07, 2010 10:48 pm
by DanThe
Not all E34 sumps have them though, only the 2 litres
If you left the pressed steel scraper plate on you wouldnt have been able to fit the sump with that baffle
Re: noisey m52
Posted: Wed Jul 07, 2010 10:53 pm
by vokietis
DanThe wrote:Not all E34 sumps have them though, only the 2 litres
yes i did leave the plate...
Re: noisey m52
Posted: Wed Jul 07, 2010 10:55 pm
by DanThe
You must have used a 525 sump then which doesnt have the baffle
Re: noisey m52
Posted: Wed Jul 07, 2010 11:02 pm
by vokietis
DanThe wrote:You must have used a 525 sump then which doesnt have the baffle
yes i think so,because sump fitted with no probs at all.
Re: noisey m52
Posted: Sat Jul 10, 2010 10:58 pm
by vokietis
sorted thanks,crank was touching the plate due to my stupidity
Re: noisey m52
Posted: Sat Jul 10, 2010 11:09 pm
by Jhonno
vokietis wrote:sorted thanks,crank was touching the plate due to my stupidity
