Coolant hoses
Posted: Wed Jun 23, 2010 8:42 pm
I've got a fair few hoses and don't know where they go!
Just removed all the radiator air ducts and test fitted my 328i rad.
Thought I'd get my head around the hoses.
I have 2 thick hoses that are fairly short - these are obvious and connect to the biggest ports on the rad and go to the thermostat housing. (items 1 &2)
then, still on the engine I have a massive hose that has a fair few bends in it and looks as though it would connect to the rad at the bottom of the expansion chamber. (item 5)
There is one other port on the rad that is tiny. It's just under the expansion chamber. Also what does the little port on the head, right at the front on the exhaust side, connect to?
