Newbie with a few quwstions
Posted: Tue Nov 24, 2009 6:48 pm
hi guys,
I got a e30m convertable and i have just dropped in a 24v valve out of an e36 325 coupe. I'm having a few issues i hope u guys can help,
firstly i have installed the rad from the e36 but the pipe kinks slightly when it is connected i have only tried the top hose so far but assume the bottom is the same, (I am assuming this is bcause the rad is now closer to the block ) is there a way around this?? or do i have to fabricate some pipes.
having got the engine from a 3 series i had to change the sump so now i have 2 dip sticks and can't remember which 1 is which. Does any 1 have a pic of the 1 i need??
and lastly i have used the complete engine and box setup from the e36 (gartrag box(hope i got that right lol)) but the gear lever does not come up central in the hole so i can not select fifth although it has all bolted up ok have i done something wrong (i have used e36 engine brackets with m5 mounts) or do i just need to cut the floor???
any help u guys can give would be great
thanks malc
huddersfield uk
thanks malc
huddersfield uk
