Has anyone used a dual mass flywheel on an M3 clutch on an M52 with ZF Gearbox?
I'm using a M20 lightened flywheel and an uprated clutch, but it's a bit on-off with a high bite and I'm keen to improve driveability.
New Luk flywheels seems fairly reasonable (compared to getting a 2nd hand one and re-surfacing). But the question is - which one? M3 3.0 or 3.2? And assuming I'll need an E36 starter. Or are or the flywheels the same and it's just the clutch that differs? Trying to figure it out as it doesn't seem like a common swap.
Cheers,
Gus
Dual Mass Flywheel + M3 Clutch
Yep am using that - it's more the fact it's an aftermarket uprated M20 clutch, one side is paddles
