I have been working on my friend swap, and it doesn't want to start.
I checked at the fuel pump relay and I found that it is not working. So I'm thinking that maybe the ews could be the problem, but I'm not sur if it was an ews car or not.
The DME is a 0261200413 red label ecu. Does this one come with ews? If yes how can I get rid of it. And if it's not an ews ecu what could hold my fuel pump relay from working?
If it can help the harness come from an 94 e36, when I looked, I didn't found any ews controler and there was no ring antenna.
Thanks (sorry for my bad english
