Brown temperature sensor
ross_jsy
Sun Feb 02, 2014 10:27 pm
Ran the car up till the top hose was warm today and noticed the temperature gauge hadn't moved. Checked the temperature sensors in the head (came out of an e30 so assumed they had been changed) and the left one was blue but the plastic on the right one was black. Am I right to assume this should be brown, and this is why I am having issues?
Sun Feb 02, 2014 11:42 pm
Yep, part number 12621710512
ross_jsy
Sun Feb 02, 2014 11:43 pm
Awesome cheers Dan, a local e30 owner has a spare which I'm picking up tomorrow.
Motorhole
Mon Feb 03, 2014 9:13 am
Also make sure you don't have the oil pressure sender plugged into brown temp and vice versa :o:
ross_jsy
Mon Feb 03, 2014 12:10 pm
Used Dan's loom so all plugs were labeled up :)
