M52 oil cooler
were abouts are you? as iam currantly fitting one to my m52 powered e36 after being told cant be done!ive just got to get a couple of bits machined up then i can fit it,there is several differant ways of going about.
Yep. S50 filter housing and cooler is the best solution in my opinion.
This was the route I was going to take with my M52 as well.
Seen quite a lot of made up kits that use a machined oil filter cap too but it doesn't look as neat to be honest.
ross_jsy
BMW would have figured out they were not needed to keep oil temperatures at good levels.
Unless you are using your car for track use or oil temperatures become a problem I would question the need for one.
The quality and properties of oil has improved significantly since the days of the M20b25s needing oil coolers when used just as a road car.
With good oil, there really was no need for a cooler on an E36 328 etc. Actually, having a cooler may have done more harm than good in some cases as it may keep the oil from reaching optimum operating temperatures quickly (similar problems to dry sump system on a road car etc)
The M3 was always going to be a car that was driven harder and the S50 would have produced more heat so the cooler was fitted on that first day alright obviously.
Still, if not just pottering around to and fro from the shops, a cooler would be useful on M52 engined E30 especially if it has a few nice bits like the M50 inlet, cams, map etc to allow it to be driven even harder
you can fit an oil cooler to the standard housing if you make the parts up like i have just done so it's not the only way by using an s50 part but if you can't machine your own parts the price will probably be cheaper to do so.
kev
kev
Learn something new every dayDanThe wrote:The oil coolers are thermostatically controlled Dave, no chance of overcooling
Still... Those kits that you get that have a hole in the filter housing cap are hardly thermostatically controlled.
Whole set for 100 quid was great value by the way. The coolers and lines can be expensive as they can be damaged reasonably easily.
