M30 engine query
Posted: Fri Dec 23, 2016 11:47 am
Hi,
I have recently acquired a Marlin Sportster kit car, an impulse buy after one to many beers down the local pub. it is a complete rolling shell, though it has been an abandoned project for over ten years and never been on the road. Anyhow the purchase came with an engine and manual box from a mid eighties E23 7 series. It is the 3.5 ltr engine.
the previous owner said he ran the donor 7 series for six months or so before removing the engine and box and claims it ran well with the only issue being small puffs of blue smoke on the overrun, which usually means valve stem oil seals. I have the engine on an engine stand and plan to strip it over the next few weeks.
I only intend to replace the valve stem oil seals, head gasket and all other gaskets, and the water pump. Probably the clutch and clutch slave cylinder as well. I have not worked on an M30 before which is a bit different to the M42 and M25 engines, or maybe not ??
I don't have any plans to modify the engine, 218bhp and loads of torque is enough I think on a car weighing about half an E30.............
Questions; Are there any particular problems with changing the valve stem oil seals ? and can I reuse the cylinder heads bolts or do I have to replace these with new ones on re assembly.
I also have the original engine wiring loom and ECU and I am unsure on how best to connect this into the not yet fitted basic loom for the Marlin. Would it be as simple as connecting the engine loom, including the Ignition and fuel pump wiring, into the ECU via the original plug and then just providing a separate live feed to the ignition switch and the ECU from the main loom.
Anyone any ideas on how best to do this.
All constructive comments welcome
Jim
Jim
