M30B35 Engine swap - looking for a chip?
Posted: Fri Jan 16, 2015 1:16 pm
by Sykopaf
I've not been around in a while but I bought a processor for my ECU maybe a year or 2 ago from one of the members here. I'm after another one, is anyone around who still does that?
Re: M30B35 Engine swap - looking for a chip?
Posted: Fri Jan 16, 2015 6:53 pm
by Bristol_Jer
Speedtouch does one, he's got a thread running in the forsale section iirc. I've got one fitted in mine
Posted: Fri Jan 16, 2015 7:49 pm
by Sykopaf
Cheers, couldn't remember where I got it from last time. Somehow managed to fry every relay in it including the processor!
Posted: Fri Jan 23, 2015 10:10 pm
by zaust
either speed touch or look up Jason, chipped uk I run the lairy one from Jason. big smiles all the way.
Posted: Fri Jan 23, 2015 10:36 pm
by Speedtouch
Chip has been sent and is on it's way to you, Joel.
Posted: Thu Jan 29, 2015 5:39 pm
by Sykopaf
Speedtouch wrote:Chip has been sent and is on it's way to you, Joel.
Received, cheers bud
Posted: Thu Jan 29, 2015 10:02 pm
by Speedtouch
Thanks for letting me know.
Posted: Wed Feb 04, 2015 4:34 pm
by ajh300
Does a chip make much difference to the m30 3.5? toying with the idea of putting one on mine
Posted: Wed Feb 04, 2015 6:05 pm
by Bristol_Jer
Did on mine, definitely felt like it had a bit more go than before when accelerating. It raised the rev limit a bit too, but you won't need the higher revs on a standard engine as all the grunt is down low.
Couldn't comment on the mpg as mine isn't a daily driver so never bothered with checking what it does to a tank
