M30 with e34 manual box best short shifter
Posted: Sat Dec 14, 2013 10:48 pm
by seanboy
Guys dropping a boat anchor in over the festive period.
What's the best option/part number for a e34 manual box short shifter?
Z3?
Re: M30 with e34 manual box best short shifter
Posted: Sun Dec 15, 2013 2:16 am
by Rav335uk
For a start, the "Correct" term to use is "M52 BEATER"!!!! has to be used in this section!
Posted: Sun Dec 15, 2013 2:00 pm
by Cypriotgeeza
Rav335uk wrote:For a start, the "Correct" term to use is "M52 BEATER"!!!! has to be used in this section!
+1
Posted: Sun Dec 15, 2013 2:31 pm
by jimbom30cab
+2
I have a Z3 short shifter and to be honest i prefer the original 325i shifter
Posted: Sun Dec 15, 2013 4:25 pm
by seanboy
My "M52 Beater"!! Lol has E34 530i gearbox.
Would a 530 box have similar ratio's as putting a e30 320i box on a se e30 325i?
They reckon the 320i box are similar ratios to the 325i sports! That's what I'm getting at.
I had M52 Beater a few years back and thinking of it the standard gear throw was pretty tight!
Posted: Mon Dec 16, 2013 1:00 pm
by gareth
I've got a M30B32 with a 530 box and 1.9 Z3 shifter, works nicely
a new shift knuckle for the box will help with 'slop' so worth fitting while it's all on the floor
Posted: Mon Dec 16, 2013 9:31 pm
by seanboy
Any other mods while on the floor,
Rocker arm settings etc?
Posted: Mon Dec 16, 2013 9:55 pm
by jimbom30cab
gearbox selector shaft seal is a must !!
new clutch slave cylinder as they are so cheap, last one i bought from CP4L was £3 (yes three quid)
check the rear of the cylinder head blanking plate gasket is good and not leaking as it will be a head off job to change
new oil pressure swich is an easy win, it's a pain to get to once fitted.
check the blanking cap on the underside of the inlet manifold
have a look at the condition of your dizzy cap and rotor arm, this job is probably 5 mins on the floor and almost impossible when fitted.
maybe water pump - only £20 from CP4L
Hope that helps
Posted: Tue Apr 22, 2014 9:29 pm
by mccarthy
Hi all, sorry to jump on this thread but I have a 1.9 z3 shifter on an m30 box but it sits quite far forward I.e 2nd/4th is more like neutral position. Is this correct or has a wrong part been used?
Posted: Tue Apr 22, 2014 9:51 pm
by jimbom30cab
Its probably the length of the selector arm which isn't quite right ?? I have the same set up as you describe and it sits in the middle fine.
is the back end of the rod secured in the little bracket underneath ?
Posted: Tue Apr 22, 2014 11:47 pm
by leeparkes
Twist the shifter 180 degrees?
Posted: Wed Apr 23, 2014 8:14 am
by mccarthy
I had it done at a garage, perhaps it is as lee says 180 degrees out? Will investigate this weekend. Thanks for the advice and will post findings Sunday. Cheers
