M5 clutch
Posted: Tue Aug 13, 2013 12:38 am
So I sourced a e28 single mass and wanted to put uprated/fast road ( call it what you will) clutch in !
Then I thought e28 m5 ! Would it fit ? Should have a beefier pressure plate !
And instead of following my gut in thinking it would fit , I did a ill research and only got confused by sh1t.
So I went on Realoem and cross referenced part numbers of both e28 535i/m535i to e28 m5
And they were different ?
So here I am
Will a e28 m5 clutch pressure plate etc
Marry up to a e28 535i/m535i single mass flywheel
Also I have dual mass bolts off old e34 fly !
Can these be used or are they longer ?
So here I am
