m30b35 headgaskets
Posted: Sun Oct 28, 2012 8:41 pm
by wixsy
Wheres the best place to get these, or are they readily accessible from car factors. If i end up turboing it, what thickness headgasket do i need and where would i get these. Also are head bolts reusable and if not where do i get these, thanks
Re: m30b35 headgaskets
Posted: Sun Oct 28, 2012 9:01 pm
by jimbom30cab
i've been told that the best place for the head gasket is OEM, i.e the dealers, i believe you can re-use the head bolts also
Posted: Sun Oct 28, 2012 11:00 pm
by Rav335uk
Re-using head bolts on an M30 is not advised, you're meant to use NEW ones.
As for H/G, pm "Meatballs" aka Matt @ Eurocarparts, he does Elring H/G's.
Posted: Mon Oct 29, 2012 2:52 pm
by wixsy
How thick do i need if i choose to turbo it, which is becoming more likely,
Posted: Mon Oct 29, 2012 5:02 pm
by Rav335uk
You can use the standard H/G upto ceretain HP.
But I think most get the MLS H/G
Posted: Tue Oct 30, 2012 1:30 pm
by shedrool83
