Rev counter not working, someone please help!
Posted: Thu Feb 24, 2011 6:58 pm
by sheebie
Rev counter still not working. Im not sure why
I have done the swap on the wires, The heaters work fine. The speedo works fine, SI batteries both show 3v.
But the rev counter and eco-swing meter does not work. I checked all the connections, everything seems fine. So stumped at the moment.
Anyone got any ideas?
Re: Rev counter and speedo not working
Posted: Thu Feb 24, 2011 7:47 pm
by Bristol_Jer
Is this on an M30 converted car?
Posted: Thu Feb 24, 2011 10:52 pm
by leeparkes
Do the temp and fuel gauge work as normal?
Posted: Thu Feb 24, 2011 11:23 pm
by sheebie
Yeah they work fine, so it must be the wiring i think
Posted: Wed Mar 09, 2011 8:18 pm
by sheebie
A little update.
I checked the batteries on the SI board they both read at 3v so no problems there.
The speedo was not working due to a loose connection. So thats sorted now. I love the way when changing from 1st - 2nd the speedo bounces when you loose traction. Also, good to see how fast Im going finally.
However the Rev counter is still not working, I have been searching on this forum and others it seems like a few people have had trouble with getting them working. But cannot find a solution anywhere. Got some details about running a wire to the c103 connection but nothing certain anywhere.
What the trick to getting the rev counter working?
Posted: Sun Mar 20, 2011 12:01 pm
by sheebie
Anyone?
Should this have worked when I swapped the wires over or does something else need to be done?
Posted: Mon May 23, 2011 11:14 pm
by walinsky
Early e30 models have a (3-wire) C104 connector that sends tacho (pin 1) and economy (pin 3) signals to the instrument cluster.
http://forums.eurocca.net/showthread.ph ... post559881
Posted: Thu May 26, 2011 1:03 am
by sheebie
its not a early model. I have now got used to it. Might get a dash mounted counter, but they look a bit tacky or just leave it
