M20 wiring on 3.5
ammar786
Fri Mar 25, 2011 8:04 pm
Hi guys just wanted to know if you can use the the standard wiring when doin the 3.5 conversion
I have put the engine in and I have modified the wiring to fit the engine and it is all connected up but for some reason it won't even crank
Anyone know what the problem could be
Ammar
shedrool83
Fri Mar 25, 2011 10:27 pm
Are you using the m30 engine loom?
ammar786
Fri Mar 25, 2011 11:01 pm
No the standard m20 loom
sheebie
Sat Mar 26, 2011 3:42 pm
I had a similar problem, it was an immobliser on the m20 loom that i didnt know about
ammar786
Sat Mar 26, 2011 7:40 pm
Yea mate all the wire are connected and there is no immobiliser as far as I can see
Still don't know what it is it's really frustrating :-x
ammar786
Sat Mar 26, 2011 8:47 pm
I get ignition lights
And I haven't tries to bridge a
Out any wires do you know what colour they are and I'll have a look tomorrow
ammar786
Sat Mar 26, 2011 10:20 pm
What do I need to do short them together or swap them round
ammar786
Sat Mar 26, 2011 11:12 pm
Thanks for the drawing but do I need to swap wire 111 with 14 and 14 with 11 or put a piece of wire between 11 and 14 to short them together
shedrool83
Sun Mar 27, 2011 7:26 am
Just use a piece of wire between them.
zaust
Zone day release
Sun Mar 27, 2011 10:24 am
Have you put the earth strap from engine to body fella ?
M30 Tech 1 Touring on gas.
ammar786
Sun Mar 27, 2011 11:57 am
Yesate I've put the earth to the body
ammar786
Sun Mar 27, 2011 7:58 pm
Finally got it started today and it sounded like a spitfire poplin and banging even my neighbourh came round to see what had happened
The problem why it woudnt start was a snapped wire to the starter motor
What a joke especially after spending 3 days trying to sort the problem out
Thanks for all the help I have recieved its much. Appreciated
