m20 bhp
Posted: Mon Sep 09, 2013 6:54 pm
by drai
what is the highest bhp recorded or u can get from a m20 engine. iv been told the most u can get is about 220 bhp from hartge h27 engine. can a higher number be achived without fitting a turbo
Re: m20 bhp
Posted: Tue Sep 10, 2013 8:15 am
by reggid
your source is full of BS ive seen 221bhp before.....
Re: m20 bhp
Posted: Wed Sep 11, 2013 8:19 pm
by leeparkes
Iirc you can get an M20 to a 3.1ltr so i guess with cam, head work. etc it will be more than 220bhp
Re: m20 bhp
Posted: Wed Sep 11, 2013 8:24 pm
by MattTheHat325
Big power m20's cost big money! I'm sure the most powerful naturally aspirated one I've ever come across was around 265 bhp. I think it was in the states? Someone must know which one I mean. Can't remember the spec but I'm sure it was a 3.0 or 3.1 stroker on throttle bodies.
Re: m20 bhp
Posted: Wed Sep 11, 2013 8:26 pm
by maggspower
It all depends on how much money you have to chuck at it.
For 220bhp you are going to have to build a well sorted motor. And anything above that is going to have to have a considerable amount spent on it. It obviously needs to be put together right as well, its not as simple as having all the parts.
Posted: Mon Sep 16, 2013 2:17 pm
by e21jps
this is at the wheels on a chassis dyno, engine power possibly 25% higher. The money spent on this is not as high as one might think. It mostly takes a carefully matched set of parts and a really good head porting job.
link about the build here
http://www.e30tech.com/forum/showthread.php?t=117701
Re:
Posted: Mon Sep 23, 2013 8:44 pm
by Rallyprep_UK
Nice work Rama :-)
Re:
Posted: Mon Sep 23, 2013 8:51 pm
by jimbom30cab
Bryon,
What do you think this would give?
B27 bottom end with 325 head fitted with newman 270/270 cam
Btb header
BBTB
M30 AFM with 19lb injectors
Bespoke map
Lightened fly
All refurbished so like new :D
Jim
Re:
Posted: Wed Oct 02, 2013 5:39 am
by morerevsm3
most powerful NA M20 is this one I believe-
big dollar engine though
Re:
Posted: Mon Dec 30, 2013 12:07 am
by Fastroad
What's the cheapest way to get a standard 325i sport to 200bhp (without changing from a M20)
Re:
Posted: Thu Jan 02, 2014 11:20 am
by pacerpete
There ain't a cheap way ! :(
Re:
Posted: Thu Jan 02, 2014 1:37 pm
by MattTheHat325
Fastroad wrote:What's the cheapest way to get a standard 325i sport to 200bhp (without changing from a M20)
Keep an eye on the for sale section for a bolt in 2.7 I'd say....
Re:
Posted: Thu Jan 30, 2014 11:31 am
by hongkongfuey
cam and chip/map( to get closest to without major building)
Re:
Posted: Thu Jan 30, 2014 11:38 am
by Quaser
my 2.7 was 230bhp - high compression engine, 2.0 block skimmed and bored out for 2.5 pistons, head ported and polished, 525e crank, 2.0 rods, 2.5 pistons and head, btb2 manifold, shrick 272/268 cam bbtb, itg air filter, m30 535 injectors with fpr, unichip and mapping.
Re:
Posted: Fri Jan 31, 2014 1:06 am
by reggid
Quaser wrote:my 2.7 was 230bhp - high compression engine, 2.0 block skimmed and bored out for 2.5 pistons, head ported and polished, 525e crank, 2.0 rods, 2.5 pistons and head, btb2 manifold, shrick 272/268 cam bbtb, itg air filter, m30 535 injectors with fpr, unichip and mapping.
got a RR plot? its always interesting to see the power delivery difference between various engines
Posted: Fri Jan 31, 2014 1:26 am
by Kos
e21jps wrote:this is at the wheels on a chassis dyno, engine power possibly 25% higher. The money spent on this is not as high as one might think. It mostly takes a carefully matched set of parts and a really good head porting job.
Impressed, the cam kick makes a the Vtec kick seem smooth lol
Seriously impressed and pleased that there are people, still tuning m20's
Posted: Sun Feb 02, 2014 4:29 am
by reggid
if you look at the other dyno plots of m20 cars on this particular dyno( on e30tech) the dyno operator must have started the run not at WOT and then eased into WOT so the low speed/rpm numbers are skewed lower.
Re:
Posted: Sun Feb 02, 2014 11:10 am
by Kos
Fair point, but I did watch the video of it on track where the cam kick is quite noticeable
Re:
Posted: Sun Feb 02, 2014 12:29 pm
by miniblob
Cam kick is quite noticeable on my 2.7 - pushing 220bhp with a 285/285(?) cam - it really launches abover 3.5k rpm!!!!
Personally, I wouldn't bother trying to do another powerful M20 - there's plenty of BMW engines that will put out 'better' power (& delivery) and be more cost effective - and still tuneable if you want a bit more down the line.
I've spent way too much on mine!!!
Re:
Posted: Sun Feb 02, 2014 1:23 pm
by steve_k
Hoping to get my 2.6 m20 on the rollers soon (after the Mac conversion) to see what kind of power it's putting out (all ready got a pretty good spec so fingers crossed).
Re:
Posted: Sun Feb 02, 2014 8:52 pm
by reggid
miniblob wrote:Cam kick is quite noticeable on my 2.7 - pushing 220bhp with a 285/285(?) cam - it really launches abover 3.5k rpm!!!!
catcams are bad like that. with the OEM manifold it is really pronounced on mine it was the same.
