Head strip - cleaning components
Posted: Sat May 11, 2013 9:46 pm
Hi all,
Well I’ve started the process of rebuilding the engine in the cab and last week got the head off the block.
I’m planning to get the head over to the machine shop next week to get pressure tested, minimum skim, new guides and stem seals.
Before I give the head I need to strip all the internal components valves, cam, rockers etc.
While the head is getting the work done at the machine shop I would like to clean the valves with all the carbon build up at home. Question is what can I use to clean the carbon build up?
Any other internal head parts that could do with a clean as above?
Thanks in advance.
Thanks in advance.
