Got no spark,correct ecu?
Posted: Tue Dec 04, 2012 1:02 pm
by macas
My mate is doing his 88 cab 2ltr to 2.5 ltr engine swap and has a brown cable at pin 20(body loom side)which i have heard could become a problem?
The 2.5 he is installing is out of an f plate auto cab,could this be an issue?..thanks
Edit.....This has been sorted now...
Re: Found brown wire at pin 20?
Posted: Tue Dec 04, 2012 1:05 pm
by Mikey_Boy
Have a butcher's here:
http://www.e30zone.net/modules.php?name ... ic&t=83367
Should tell you all you need to know...
Posted: Thu Dec 06, 2012 9:53 pm
by macas
Right,engine is in but now have no spark,there is no power at the ecu(i think),should there be power at pin 87 of this main relay to power the ecu when ignition is switched on?
Also this is the ecu...which pin should be powered up with ignition on?
Posted: Thu Dec 06, 2012 9:58 pm
by macas
I should add that there is a white plug with three cables going into it above the ecu,white,green and a black,have these any significance?they are not plugged into anything?
by Speedtouch
It's odd that an F-reg car would have an 073 ECU, as these were only fitted to pre-facelift cars (i.e., D-reg or earlier).
Most F-reg 325i's have the later 173 or 380 ECU.
Are you sure it's the ECU supplied with the engine he's fitting?
There are fundamental differences - the 073 ECU uses two crank position sensors, one fitted to the flywheel, whereas the 173/380 just has the one CPS. The number of pins to the ECU differ also - later ones have 55 pins, arranged in 3 rows, while the 073 has 2 rows of 35 pins.
Posted: Thu Dec 06, 2012 10:02 pm
by macas
Speedtouch wrote:It's odd that an F-reg car would have an 073 ECU, as these were only fitted to pre-facelift cars (i.e., D-reg or earlier).
To be fair mate,i found out today the engine is an e plate 88,the ecu that came off the 2.0 had 3 rows of pins,now this ecu has 2 rows of pins,so the mechanic thats doing the work had to swap the ecu loom?....i hope that makes sense?.
Posted: Thu Dec 06, 2012 10:05 pm
by Andros
Nice 1 for ur help macas I Wudnt av ad a clue where to start lol
Posted: Thu Dec 06, 2012 10:16 pm
by Speedtouch
Well, be sure to let the mechanic know that the earlier 073 ECU requires two CPS, fitted to the flywheel:
http://www.e30zone.net/e30zonewiki/inde ... Management
It would have been better to stick with the original 55-pin Motronic 1.3 loom and fit the later and better 173/380 ECU!
Posted: Thu Dec 06, 2012 10:23 pm
by macas
Speedtouch wrote:Well, be sure to let the mechanic know that the earlier 073 ECU requires two CPS, fitted to the flywheel:
Right,so am i right in thinking that he could have just swapped the 2.0 ltr ecu fir a 2.5 one with the three rows of pins?....
by 320
Just scrap it. Only playing. The 3 pin plug wires are no1. Instrument panel signal, (fuel gauge). No2. Teach signal. No. Ingition switch signal (to motronic).
Posted: Thu Dec 06, 2012 10:28 pm
by macas
320 wrote:Just scrap it. Only playing. The 3 pin plug wires are no1. Instrument panel signal, (fuel gauge). No2. Teach signal. No. Ingition switch signal (to motronic).
But what colours are those?
Shouldnt that be "tacho"? And not teach?
Posted: Thu Dec 06, 2012 10:32 pm
by Speedtouch
No need even for that; just use the 320i ECU and fit a 325i chip in it. They are identical apart from the EPROM chip!
Posted: Thu Dec 06, 2012 10:33 pm
by macas
Tbh hes gettin a chip off you next week aswell!!...
Cant beleive it was that easy....
Posted: Thu Dec 06, 2012 10:34 pm
by 320
macas wrote:320 wrote:Just scrap it. Only playing. The 3 pin plug wires are no1. Instrument panel signal, (fuel gauge). No2. Teach signal. No. Ingition switch signal (to motronic).
Yes well pointed out, now go scrub your finger nails they fookin terrible
Posted: Thu Dec 06, 2012 10:38 pm
by macas
320 wrote:macas wrote:320 wrote:Just scrap it. Only playing. The 3 pin plug wires are no1. Instrument panel signal, (fuel gauge). No2. Teach signal. No. Ingition switch signal (to motronic).
Dont forget your little basket for the front of your bike so you can carry your jam sandwiches forlunch tomorrow..
Posted: Thu Dec 06, 2012 10:39 pm
by 320
rofl
Posted: Thu Dec 06, 2012 10:42 pm
by 320
Chicken paste actually
Posted: Thu Dec 06, 2012 10:45 pm
by Andros
I got marmite lol
Posted: Thu Dec 06, 2012 10:47 pm
by macas
by 320
Would different eprom chip make any sort of difference to the way it runs
Posted: Thu Dec 06, 2012 10:54 pm
by macas
Do you mean him leaving in the 2.0ltr chip on the 2.5 engine?
Posted: Thu Dec 06, 2012 11:01 pm
by Andros
How long wud it take for the chip to reach me if I jus do it that way
Posted: Thu Dec 06, 2012 11:09 pm
by 320
no. If he put the 320 ecu bac on and put the 325 chip in it would it run any different because of the rom chip difference. And have to swap the loom back over
Posted: Thu Dec 06, 2012 11:10 pm
by Speedtouch
I post them First Class, so it should reach you in a day or two.
Putting a 325i chip in a 320i ECU will make it run exactly as if a 325i ECU were fitted, unless you put one of my upgrade chips in, of course.
Posted: Thu Dec 06, 2012 11:14 pm
by Andros
Yes it's the upgrade chip I'm after how much is that plz
Posted: Thu Dec 06, 2012 11:15 pm
by Speedtouch
PM sent!
Thanks,
Posted: Fri Dec 07, 2012 12:11 pm
by Andros
The engine I have ad put in was out of an automatic car does this matter
Posted: Fri Dec 07, 2012 1:19 pm
by Speedtouch
See my reply on your other thread.
