320 head on a 325 block?
Posted: Sun Nov 06, 2011 9:54 pm
by antony_e
As above ive had a search but nothing i can make a good yes or no to
appreciate any help
ant
Re: 320 head on a 325 block?
Posted: Sun Nov 06, 2011 10:51 pm
by HairyScreech
its generally a no, take a look at page 12 of my thread.
Posted: Sun Nov 06, 2011 10:53 pm
by antony_e
Always worth a try i guess cheers for the reply
Posted: Sun Nov 06, 2011 10:54 pm
by Quaser
no - 325i pistons are shaped - 320i are flat!
Posted: Sun Nov 06, 2011 11:07 pm
by HairyScreech
which is what i was referring to there, you need to remove material from the head in order to prevent the pistons clashing at the squish band.
the head in my thread has been modified to suit.
although.... its just not worth it, all you will get is a slower car.
Posted: Mon Nov 07, 2011 12:36 am
by daimlerman
Depends on what pistons you use...
I am using a 325 block with a 731 head,but eta pistons,rods and crank....
Posted: Mon Nov 07, 2011 12:41 am
by HairyScreech
very true, in general a 731/320 head MUST have FLAT pistons and an 885/325 head MUST have BOWLED pistons.
otherwise you are buggering up the design of the combustion chamber.
have you seen the latest on the m20 thread? there may be help for you eta piston knuckle draggers yet.
Posted: Mon Nov 07, 2011 1:37 pm
by daimlerman
HairyScreech wrote: there may be help for you eta piston knuckle draggers yet.
I'm watching!
Now if we can combine M50 sequential fueling and COP,can we get an engine that 'looks' stock,but is more efficient?
Posted: Mon Nov 07, 2011 6:15 pm
by HairyScreech
thats the plan.
cause with the way fuel prices are going.......
(ohh and lpg, as the m50 management will run lpg a LOT better than the m3.1)
