could an m20.......?
Posted: Thu Sep 22, 2011 8:39 pm
by HairyScreech
could an m20 be converted from belt to duplex chain drive?
not really thinking about actually doing it, but have been toying with the idea just for funsies.
i think it should be possible, using an m50 crank pully, a shortened m50 chain and tensioner, some kind of modified cam pully and scratch building a chain box.
Re: could an m20.......?
Posted: Thu Sep 22, 2011 9:30 pm
by bss325i
M30 cam pulley?
Posted: Thu Sep 22, 2011 9:32 pm
by HairyScreech
good thinking, im tempted to mock it up, "just to see".
Posted: Fri Sep 23, 2011 12:16 pm
by 320Touring
Biggest issue would be creating a tensioning system and a lubrication system..
Posted: Fri Sep 23, 2011 12:49 pm
by gcs325i
Was Alex/Turbo-Brown not looking in to chain driven m20 for his twin turbo build? It may have been just the dry sump oil pump drive but may be worth a read.
http://www.e30zone.net/modules.php?name ... mp&start=0
Posted: Fri Sep 23, 2011 1:23 pm
by e301988325i
Sufficient lubrication could probably be provided by removing the crank and camshaft (edit added) oil seals, seems like an interesting prroject!
Posted: Fri Sep 23, 2011 9:13 pm
by HairyScreech
^^^ thats what i was thinking, no front main and have it in the stock m50 position. (hence the need for the 2.8 oil spacer)
im not really thinking of doing it, but i might mock it up just to see.
Posted: Fri Sep 23, 2011 9:27 pm
by DmcL
what about a change in the rocker spray bar setup? make a longer spray bar and run it out over the chain/cam sprocket with an additional spray hole.
Posted: Tue Sep 27, 2011 11:27 pm
by bss325i
You need a pressurised oil feed to the tensioner.
Posted: Wed Sep 28, 2011 12:18 am
by HairyScreech
thats easy, external take of from a t-piece on the main oil gallery, like you would with a turbo feed.
