slight hesitation under load...
Posted: Wed Oct 28, 2009 9:31 pm
by E30WES
Gents when driving in a fashion that can only be described as 'spirited' the m20 seems to hesitate then clear and continue to pick up like normal. Although, maybe just me but have noticed that the old girl does seem a little down on power?!! Any thoughts?
Regards
Re: slight hesitation under load...
Posted: Wed Oct 28, 2009 11:44 pm
by Gunni
Do a quick tune up check.
look at the plugs, leads, cap and rotor for wear.
measure the leads to be close to 5600ohms. Higher will mean less voltage get´s to the plugs.
Measure the gaps on the plugs.
Look for vacuum leaks.
Posted: Fri Oct 30, 2009 12:59 am
by Silverfang
Would also check the idle control valve, they can stick on time to time.
Posted: Fri Oct 30, 2009 11:39 am
by fowler
possibly TPS or DME can also be a culprits
