80 celcius where the temperature gauge needle sit?
markus_74
- Contact:
Now, my engine running without thermostat and needle gauge sit at 1/4 (first white line after the blue).
And if I install 80 celcius thermostat where gauge sit?
And I read at several forums does is it necessary to make hole in the edge of thermostat to make morr easily to bleed?
Originally it has small hole with small metal ball.
Thank you in advance
Markus
Markus
HairyScreech
I thought they were directly up/inline with the 1/2 mark with a 80? or is that the 88?
HairyScreech
Looks pretty normal to me, mine with the 88 sits at 50% and sometimes hover about 10 degrees to the right under some conditions.
- Brianmoooore
Gauge will rise slightly before the viscous coupling locks and the fan kicks in. You are chasing a problem that doesn't exist.
