slight hesitation under load...
E30WES
Wed Oct 28, 2009 9:31 pm
Gents when driving in a fashion that can only be described as 'spirited' the m20 seems to hesitate then clear and continue to pick up like normal. Although, maybe just me but have noticed that the old girl does seem a little down on power?!! Any thoughts?
Regards
Gunni
Wed Oct 28, 2009 11:44 pm
Do a quick tune up check.
look at the plugs, leads, cap and rotor for wear.
measure the leads to be close to 5600ohms. Higher will mean less voltage get´s to the plugs.
Measure the gaps on the plugs.
Look for vacuum leaks.
With great challenges comes great engineering.
Gunni
@ 2012 VEMS group buy !!
Silverfang
Fri Oct 30, 2009 12:59 am
Would also check the idle control valve, they can stick on time to time.
BMW and Opel, both RWD, both german, both good fun
http://www.clockservicing.co.uk/ For any clock repairs try here.
fowler
Boost Junkie
Fri Oct 30, 2009 11:39 am
possibly TPS or DME can also be a culprits
EX A-Tech Workshop bitch !!!
gone but not forgotten
