Track day suitable coilovers
Posted: Mon Feb 22, 2016 10:54 pm
by jessieparsons1
Going to start doing a few track days in my e30, looking for a good set of coilovers to raise the car (currently has about an 80mm drop on springs winkeye )
Want something that's height adjustable (hence coilovers) but not nessecerily damper adjust and the rest. Don't want to spend loads but can anyone recommend an above budget system that isn't going to break and get knackered on track. Ideally between £250-500. Don't mind second hand bits if anyone has anything.
Re: Track day suitable coilovers
Posted: Tue Feb 23, 2016 6:50 am
by Motorhole
FK are height adjustable only and use Koni inserts. Probably the best quality you'll get new for that sort of money but I'd also imagine they are quite street focussed. Might be a bit soft to get the best out of the car.
Posted: Tue Feb 23, 2016 7:57 am
by jessieparsons1
Okay thanks, il have a look into some FK's. Not looking for ultimate performance as I certainly can't drive well enough to require that but like I said something above budget and adjustable! Cheers!
Posted: Tue Feb 23, 2016 8:50 am
by Motorhole
I suppose an added benefit is if they take Konis, you should be able to upgrade to single or double adjustable inserts in the future and upgrade the spring rates - if budget suits.
Posted: Tue Feb 23, 2016 9:52 am
by steve_k
i've used FK's koenniggsport coilovers in the past,
as motorhole says they use koni inserts (shorter mk2 golf inserts IIRC) so can be replaced easily enough,
also if you want to change the springs get them from Faulkner's, just choose your weight & free length.
as for upgrading the inserts there are plenty out there to choose from & they can be serviced by plenty of places, just search koni service centre to find one.
Posted: Tue Feb 23, 2016 6:08 pm
by jessieparsons1
Nice one thanks. Il have a look at some FK's and hopefully order some up before next month! Cheers for your help.
Posted: Wed Mar 02, 2016 11:49 am
by jessieparsons1
Anyone know where I can source these from, Google send back BC's when I search for these!
Posted: Fri Mar 04, 2016 8:40 am
by Motorhole
Would've said Euro Performance but it looks like they might've gone under? Website is offline. Might take a bit of effort to track down but surely the coilovers still exist?
Posted: Tue Mar 08, 2016 10:03 pm
by jessieparsons1
Yeah can't find them! Looked through everything I could from Google... I guess I just need to wait for someone breaking a track project or wait for next month and get something that will be the nuts!
