Spring rates
Posted: Tue Mar 10, 2015 1:36 am
by initial_g
What spring rates are people running? Im currently running 320f/400r and it feels a touch squidgy
Re: Spring rates
Posted: Tue Mar 10, 2015 7:52 am
by Motorhole
Well squidgy!
I was running the Koni coilover springs (E36 Compact) on the front and Apex springs on the rear - I think about 340/380 or something. The sump was hitting the road on the dip after lodge corner at Oulton Park and far too much roll.
Swapped to 450 Faulkner springs on the front and back to the Koni rear springs, which are about 450 also I think. Front springs made the world of difference. Back still feels soft, but it's what I had lying around...
BC do custom rate barrel springs on their website. I mean to invest in a pair at around 550lb.
Edit: lots of people rate around 600/600+ but I do still use my car on the road so it seems a little severe. And that much change would really mean revalving the dampers too.
Re: Spring rates
Posted: Wed Mar 11, 2015 2:40 pm
by initial_g
Cheers chap, im ordering new coilovers I think im going for bc, and they do state they do custom springs with the order cheers mate
Re: Spring rates
Posted: Thu Mar 12, 2015 12:49 pm
by initial_g
Bc hold in stock the following spring rates
12/12kgs
6/6kgs
10/12kgs
9/8kgs
Re: Spring rates
Posted: Thu Mar 12, 2015 12:55 pm
by steve_k
graham. if you cant find what you want off the shelf then try these
http://www.coilsprings.co.uk/
worth a try, a mate of mine had a set of springs made by them a while back & they seem to pretty well made.
they even do lightweight titanium "race" springs winkeye
Re: Spring rates
Posted: Thu Mar 12, 2015 4:23 pm
by initial_g
Cheers steve :cool: ive ordered 10kg/12kg (560ib/672ib) with the kit from bc. Im hoping this wil be ok
Re: Spring rates
Posted: Thu Mar 12, 2015 4:55 pm
by Motorhole
I reckon that will be bang on. They claim to valve their dampers to suit and pick matching pairs of dampers using test results. Let us know how they go!
Re: Spring rates
Posted: Wed Dec 09, 2015 4:17 am
by initial_g
[quote="Motorhole"]I reckon that will be bang on. They claim to valve their dampers to suit and pick matching pairs of dampers using test results. Let us know how they go![/quote
Had a couple of sessions on them now over the moon with them they do have 20% stiffer cartridges the adjustment is phenomenal hate them very highly and definitely feel better than the gaz a‘a
Re: Spring rates
Posted: Wed Dec 09, 2015 8:55 am
by DanThe
Ive changed my rears from 550lb down to 320lb and its made the car a hell of a lot better
Re: Spring rates
Posted: Wed Dec 09, 2015 9:10 am
by Motorhole
Re: Spring rates
Posted: Wed Dec 09, 2015 11:44 am
by rix313
I have 110N/mm on the front and 40N/mm on the rear. That's soft! Changing up to 120N/mm front and 80N/mm rears for next year. I've I my for a little 4 pot though.
Re: Spring rates
Posted: Wed Dec 09, 2015 1:07 pm
by DanThe
Motorhole wrote:
DanThe wrote:Ive changed my rears from 550lb down to 320lb and its made the car a hell of a lot better
That's a true coilover rear, right?
Yep gaz goldzzzzzzz :)
Making the car softer sprung on the back has made a big difference, much more grip and less tail happy. The one thing I'm struggling with at the moment is getting enough neg camber on the rear, I've lowered it as much as I can without 'too much' inner arch surgery, the plan is to cut more inner arch out and lower a bit more as and when
Re: Spring rates
Posted: Wed Dec 09, 2015 3:12 pm
by initial_g
Ive took the rear arb off dan ive noticed a huge improvement inn rear grip. Still got a 24mm up front
Re: Spring rates
Posted: Wed Dec 09, 2015 7:15 pm
by DanThe
Will you be doing any track days over winter mate?
Re: Spring rates
Posted: Wed Dec 09, 2015 7:48 pm
by Bristol_Jer
I've got 600 or 650 on the front of mine (can't remember which), but it's running a m30 so weightier than the standard lump. I need to get the coilovers back to Gaz to get them revalved to suit the extra weight so I could probably get away with a softer spring then. Does work well at the moment though but there is always room for improvement!
Not fitted my rear coilovers yet as I want to tie the shock top mounts and diff mount into the rollcage first. Have the rear suspension pretty soft as it is now (b4 shock and KW -40mm spring) and really impressed with the grip and is so easy to catch and control when the rear steps out :)
Re: Spring rates
Posted: Thu Dec 10, 2015 12:30 am
by initial_g
DanThe wrote:Will you be doing any track days over winter mate?
No matey im doing the engine swap atm its stalled for the minute untill i get a getrag 265 sorted. Although the cars still mobile and running ect, im back working in derby after xmas so will have more time on my hands, i may get a track day in if one pops up at the right price
