FAO Brianmooore / E34 brake rod.
Posted: Mon Feb 18, 2013 11:27 am
Brian,
I have seen many times you making reference to the fact that the E34 RHD brake rod is thicker than the E30 and thus offers less flex. How ever both rods are in tension and not compression when the driver pushes down on to the pedal.
Am I missing a trick? How can the rod 'flex' under tension at any noticeable degree? Any links to examples?
Has anyone else made this modification?
Thanks in advance!
Andrew
Thanks in advance!
Andrew
