ARB Reinforcement - anyone done it?
Posted: Mon Mar 05, 2012 7:52 pm
I've just spent the last few hrs making up plates to weld on to the rear arb brackets, like these:
http://maxcdn.nexternal.com/bimmerworl/ ... in_300.jpg
http://www.turnermotorsport.com/image/s ... 18_325.jpg
I've hit a small problem
I've only got it tacked together so I could test fit it but it won't all go back on. I straightened the lip on the original bracket a little bit. The bush with arb won't fully push into the bracket enough to get it all on.
Before making the bracket up I test fitted the original bracket with bush and arb and I have to use the bolt to pull the bracket over the bush and have it all nice and flush. No though because of the extra bit you don't have the leverage which was why I straightened up the lip a little. It's more or less sitting against the under side of the boot but the original bolt hole is still of to far off for it to pull the lot tight.
Hope that makes sense
