Front camber.
Posted: Sat Jul 17, 2010 12:54 pm
by Boyraceruk
As I understand it all I need to do to get camber on the rear of my E30 is lower it, but the front could use some too. Is an adjustable top mount the only thing I can do or is there some other trickery to get the same effect?
Cheaper the better please.
Re: Front camber.
Posted: Sat Jul 17, 2010 12:57 pm
by davidcorden02
as far as im aware its adjustable top mounts mate
Re: Front camber.
Posted: Sun Jul 18, 2010 10:21 pm
by DanThe
The cheapest way is with some plates similar to the ones Uwe used to make
But you will soon want more
Re: Front camber.
Posted: Sun Jul 18, 2010 11:23 pm
by town325i
DanThe wrote:The cheapest way is with some plates similar to the ones Uwe used to make
Are these some you have had made up Dan?
Re: Front camber.
Posted: Sun Jul 18, 2010 11:44 pm
by DanThe
No those are what Uwe used to make
Re: Front camber.
Posted: Tue Jul 20, 2010 11:02 am
by RPM
These are ours:
http://www.raceperformancemodified.com/ ... mounts.asp
If you dont want adjustablity just fixed camber then you can just adjust standard ones by removing the studs welding some metal on the outer, removing some from the inner and redrilling
Re: Front camber.
Posted: Wed Jul 21, 2010 8:55 am
by UweM3
DanThe wrote:No those are what Uwe used to make
I know, I know, need to make some more. I am just so tied up with other stuff.
I also developed some solid mounts which won't rattle over time
(ask Jhonno) in the same style as my rubber type.
As soon time allows I will start production. Just don't hold your breath
Re: Front camber.
Posted: Thu Jul 22, 2010 9:30 pm
by driftmonkey
I've ordered some rpm front top mounts to see if it cures my chronic understeer, be testing them on track next week. I'll do a write up and some pics if I remember!
Re: Front camber.
Posted: Fri Jul 23, 2010 1:06 pm
by moggy
Just ordered and put on RPM's topmounts to see if the understeer is improved as well.
I'll report back after my race @ Cadwell tomorrow.
Re: Front camber.
Posted: Fri Jul 23, 2010 2:20 pm
by RPM
The topmounts will give you the tools to help you improve the handling/reduce understeer but only if you set the car up correctly.
There are many other factors above camber/castor that effect the handling including understeer.
Good luck at the weekend Nigel!
Re: Front camber.
Posted: Fri Jul 23, 2010 3:50 pm
by moggy
Set up by an ex WTCC driver
Posted: Sun Jul 25, 2010 8:10 am
by moggy
I can report back.
My first appearance at Cadwell was 1 year ago, and we ended up doing the 30 min qualifying and 3 laps of the race before the engine died.
This time I completed both qualifying and the race.
For information my laps times were around 6s quicker than 1 year ago.
The car has much less understeer and feels smoother. As well as having the top mounts I also bought a set of team Dynamics wheels and a new set of Toyos, plus a replacement chip bought here a couple of months ago.
The car is now becoming competitive.
Re:
Posted: Sun Jul 25, 2010 9:23 am
by Brian28
Re:
Posted: Sun Jul 25, 2010 8:34 pm
by RPM
Please to hear it Nigel!
I love Cadwell
Re:
Posted: Mon Jul 26, 2010 12:23 am
by MillRat
Great stuff. It is always very statisfying to slash seconds off your PB after modifications (money well spent).
